Old 08-30-2003, 11:40 PM   #1
bigjimzlll
bigjimzlll's Avatar
got new engine running..but theres a problem
Engine runs fine..no start up problems....I had a bung welded(brazed) to the sump of the oil pan for a oil temp gauge. Theres a pin hole in the weld and when the oil gets up to temp it leaks..Pulling the pan is not an easy task. Im thinking cleaning it..grinding it..and epoxy or some other liquid metal.. What has worked best..JB weld?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 08-30-2003, 11:52 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have used this stuff on an oil pan in the past on an 84 K car. No problems at all. Just make sure you clean it REAL good first.
I used brake cleaner on my pan first. The stuff never leaked and lasted a good 50,000 miles untill the POS went to the junk yard in the sky.
Old 08-31-2003, 12:02 AM   #3
racedvl
racedvl's Avatar
I know of a K car that has a cracked block, filled with JB weld, she's still on the road!
racedvl is offline   Reply With Quote
Old 08-31-2003, 12:06 AM   #4
Longhorn Man
Wow...I never woulda tried that!
