04-22-2015, 10:22 PM | #1 |
Lmc led mirrors w/ turn signal?
Anybody used these? I have some ugly non-factory mirrors I'm ready to replace and these look the best to me. I'm curious if they would even flash since they are LED bulbs. I couldn't find any threads on these so if anybody has them or any info please let me know, thanks.
04-22-2015, 10:36 PM | #2 |
Old member
Re: Lmc led mirrors w/ turn signal?
There shouldn't be any problem with them flashing if you run the LED flashers in the fuse box.
04-22-2015, 10:39 PM | #3 |
04-22-2015, 11:06 PM | #4 |
Old member
I ran brake light LEDs panels for several years by themself with no blinker mods. They worked fine. I have since added the front turn signals and side markers so everything in my truck is LED now. I had to put the flashers in when I went all LED's. You can try it without and if they work good if not just add the flasher.
04-23-2015, 12:12 PM | #5 |
Thanks Andy, that sounds like a good idea I think I'll order them up and see how they work out. I just didn't want to do a full led conversion if that was what was required.
04-23-2015, 01:02 PM | #6 |
Project Junkie! Fishing Poor!!
You don't have to do a full LED conversion to run these mirrors or anything for that matter. LEDs will work just fine in conjunction with standard lights. The only issue you have with running LEDs is amperage. LED lights use such a small amount that they won't heat up the contacts in a standard flasher, therefore causing them not to flash. A set of mirror LEDs will not cause that problem because all of your other lights are non LED witch heat up the contacts like always. If you convert over to all LED, or at least most LED then you will need to install an electronic flasher for them to work properly. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
04-23-2015, 01:05 PM | #7 | |
04-23-2015, 01:12 PM | #8 |
Or install ONE old school, filament type lightbult ANYWHERE in the circuit.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
04-23-2015, 05:42 PM | #9 |
I am running the tear drop led mirrors and standard flasher unit and have had no problem with them for the last year
US Army Bomb Squad 83-96 There is no problem that a suitable amount of explosives cannot solve |
04-23-2015, 05:54 PM | #10 | |
Tags |
led mirrors |
