Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 04-23-2015, 08:19 AM   #1
biohazardbill
Gas Tank Questions - Bagged Burb
What are you guys using for your gas tanks? Are you still using the factory fill neck?
I currently have an early version of the boyds blazer tank installed that doesnt have as much baffling as the current version. It is modified to allow use of the factory fill. The tank is pretty low to the ground, when laid out only is about a 1/4" off the ground so I am somewhat concerned. When on an incline the other day I hit the gas pretty hard and the truck started to die due to the rush of gas to the back of the tank (i had 1/4 tank). So I plan on replacing the tank anyway with one with more baffling so now Im looking to see what else I can do at the same time to gain more clearance.
Thoughts?
biohazardbill is offline   Reply With Quote
