Old 04-23-2015, 10:58 AM   #1
COBob'70 K-10
Windshield Fluid Pumps are CRAP!
Is it just me or is this normal? I'm now on my third wiper fluid pump in four years. They are truly a pain to replace. I'm thinking of switching to a universal electric kit setup. Unless, of course, there's a reliable unit out there that I haven't found yet.
COBob'70 K-10 is offline   Reply With Quote
Old 04-23-2015, 11:00 AM   #2
Sklptrljay
Sklptrljay's Avatar
Re: Windshield Fluid Pumps are CRAP!
Try a Scottish one!
Ba-da-bump-tish!!!
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 04-23-2015, 11:08 AM   #3
Sklptrljay
Sklptrljay's Avatar
I'll fight you now!!!
Old 04-23-2015, 11:33 AM   #4
7tee
7tee's Avatar
I ended up mounting a universal under the hood and wiring it to the old pump wiring, works great with wiper switch...
7tee is offline   Reply With Quote
Old 04-23-2015, 11:58 AM   #5
leddzepp
Moderator
leddzepp's Avatar
Get a universal one or a newer one from a junkyard. Your headaches will disappear.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 04-23-2015, 12:01 PM   #6
Lemield
Lemield's Avatar
I had the same luck with the original style pumps. I put a universal one on and wired it to my original switch...works awesome!
I think I bought the universal kit from LMC.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 04-23-2015, 12:49 PM   #7
In The Ten Ring
I have this problem coming.....my washer pump hasn't worked for 30 years....that includes the 10 years of driving the truck.
Sticker place was very "flexible" on inspections. "Oh, you're paying cash? Pass."
In The Ten Ring is offline   Reply With Quote
Old 04-23-2015, 01:50 PM   #8
cleszkie
cleszkie's Avatar
I must have gotten lucky because my replacement pump has been working fine for several years now. However, when my original pump crapped the bed, I seem to recall finding a source for a pump rebuild kit, and almost went that route. I ended up keeping my original unit in case I ever decided to rebuild the pump.
cleszkie is offline   Reply With Quote
Old 04-23-2015, 02:11 PM   #9
davepl
davepl's Avatar
I bailed on the original and went electric as well. Here's a tip that will save you many hours and days of anguish:
- Unless you are a genius and can route everything pure gravity feed, you need a POSITIVE DISPLACEMENT pump. The rotary vane pumps, which seem to comprise about 99% of them, CANNOT lift fluid.
Sorry for the shouting, I want to be clear. The rotary vane pumps I tried (3 of them) lacked the ability -even- to lift washer fluid out of the jar. That's like 4 inches at most. So find a pump with a good 8-10" lift capacity if you can.
I also tried cutting a pump-sized hole to do what is known as the "S10 mod" (search for it) with a factory bottle, which worked because it was gravity feed but I ultimately bailed on. I put the electric pump up under the fender so it all looks like stock jar, hoses, routing (mostly), and so on.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-23-2015, 03:20 PM   #10
truckster
truckster's Avatar
I put an S-10 bottle and pump in mine and it works great. It's easy to mount the bottle, and the wiring is easy as well. I chose to create a separate wire harness for my switch so I could put it back to original, but you can just splice in as well.
truckster is offline   Reply With Quote
Old 04-23-2015, 04:38 PM   #11
cdowns
cdowns's Avatar
I've used the originals with great results using new hoses and running them so they didn't kink had them last over 20years with no problems
Old 04-23-2015, 05:43 PM   #12
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Original is the way to go. For sure.
But I'm a dummy.
So, using the new rubber line for its own grommet, I attached it to the rez (1.) and ran it between the inner and the fender.
Where it came out I drilled a hole in the fire wall (2.)
Then, along the inner firewall and under the dash, I ran it up to the $20 Napa universal pump that I'd attached to the
WW motor...all inside the cab (3.)
I "Y'd" the OUT line and ran the supply thru two holes under the cowl to the wash nozzles (4.)
Save about six inches of black hose laying at the bottom side of the driver's side inner fender, it's all hidden away.
I can get at it if it leaks or breaks pretty easily without that knuckle skinning and neck relocations that seem to come with
messing with the stocker.
As we all know, the electrical just hooks up at the ww motor with two wires...routes to the WW knob so it gets used in
the stock manner. I use that same circuit for the electric choke.
That's just me.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 04-23-2015, 07:06 PM   #13
Andy4639
Old member
Andy4639's Avatar
Save yourself time and stress!
Go to local junkyard and look for a small GM vehicle and grab the washer jug with electric pump. Then look around for a vehicle with wiper nozzles and grab those as well. You will thank me later!
The wiper nozzle will make a full spray in the area you look out of!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-23-2015, 07:22 PM   #14
trac209
Did the same the factory ones are dreadful
trac209 is offline   Reply With Quote
Old 04-23-2015, 07:38 PM   #15
truckster
truckster's Avatar
That's looks exactly like a pump/bottle from an S-10. And the wiper arm nozzles are MUCH better. You just need to be aware that the original wiper arms are narrower than later models, so you might have trouble with the clips.
Old 04-23-2015, 07:43 PM   #16
Churchill
Churchill's Avatar
What a fantastic idea, Andy! Where did you put the fluid bottle/pump? Stock spot?
Churchill is offline   Reply With Quote
Old 04-23-2015, 07:52 PM   #17
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Windshield Fluid Pumps are CRAP!
That could very well be sir!...S/10
Clips are no problem at all with a little hot water and a pair of vise grips they work great!
Heat up some water then grab the nozzle and vise grip around the arm. Let cool and your done.
Old 04-23-2015, 07:53 PM   #18
Andy4639
Old member
Andy4639's Avatar
Yes!
