![]() Join Date: Mar 2015
camper special horn on the roof of the cab
my "new to me" truck has a horn on the roof of the cab.
i REALLY want this thing to work. ![]() inside there is a lever that looks like it would actuate the horn with a chain attached or something. ![]() now i have a couple questions and i am really warry (especially with all the rain we are having) taking it off and investigating anything on the roof with the potential for leaks AND after getting my haynes manual and factory service manual there is no informaiton in there about it either. soooooooo can anyone shed any light on what this thing is, how it operates and how i can plumb to it? i assume its air operated but i have no air on board yet. thanks |
Re: camper special horn on the roof of the cab
Don't think that's factory probally off a semi or something should be fairly simple to plumb. If you just want the horn harbor freight has a small 12v compressor with a tank for cheap and if it's a pull type valve just plumb the tank to it and hook a new pull to it. You could also plumb in a electric valve and wire it into your horn switch
Absolutely not factory for Light Duty C/K trucks. As a result I can't help beyond that.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 04-24-2015 at 08:14 AM. |
Do you have a conversion truck?
