rustoleum
How many of you guys have painted with it via rolling it on? I'm going to try it on my blazer. Do I need primer or is it okay?
1986 chevy k20 4inch lift 35 inch duratracs ![]() |
#2 | |
Re: rustoleum
I have a thread with lots of pics over at another forum: http://forum.73-87chevytrucks.com/sm...?topic=30802.0 To answer your questions: primer should be used over bare metal or bondo or anything except quality paint that is good. For me, I'm repairing a lot of rust and dents, but the upper half of the truck is good so I'm just paint over that and priming the lower half. I'm scuffing up the existing paint of course, with 220 grit sandpaper. |
Re: rustoleum
A couple of pics of a military M101A1 trailer I painted with a small roller and Rustoleum oil base Green. Was not trying for a show quality job. Just did a quick angle grinder wire brush of the old layers of military paint, then rolled on two coats of new. Used a brush in the corners and other spots the roller couldn't reach.
No reason you can't mix your own paint. Just make sure you make enough the first time as it is unlikely you will get a good match on the second batch. If it is warm when you paint, the paint may start to skin over if you don't hurry. |
Re: rustoleum
Thanks for posting that pic, Dead Parrot. Thats the exact color of green I might paint my truck! Good to see it before hand. That is, if I don't go with the Sherwin-Williams which I had them mix up a quart already. Another thing, the SW is twice as expensive. It doesn't dry as hard/fast and nothing I could do would help it lay flat (go to that thread I linked to earlier to see my experiment). So... glad you posted what the green Rustoleum looks like. It's a basic color, timeless.
Re: rustoleum
I rolled my own as well, three coats but did not thin at all. Lots of orange peel and do not care.
I had Home Depot try their best to color match a piece of original paint. This turned out really close.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Re: rustoleum
So the original chevy paint is all there so I can just scuff it and roll it on?
Re: rustoleum
Yes.
I primed where there was bare, and I primed going from dark blue to white.
Re: rustoleum
Well that should be easy enough than! What did you do for a wet sanding process?
Re: rustoleum
I did not do a wet-sanding process.
I did three coats of un-thinned Tremclad. I did scuff between coats. There is enough orange peel to cause canker sores. That's how I roll. *cough*
Re: rustoleum
I didn't roll it on but I love the mixed it 70/30 7 coats later not to shabby
Re: rustoleum
That's about the color I want I love that color I hope mine turns out as well since I will be rolling it on
#12 | |
Re: rustoleum
#13 |
Re: rustoleum
20 min between coats , that color is safety red in the sun it had an orangish look loved it, I called it resale red
Posted via Mobile Device |
#14 |
Re: rustoleum
Would you use the same mixture to roll it on or more mineral?
#15 |
#16 |
[look on YouTube with rolling in on you actually roll it on straight out of the can to prevent runs
#17 |
Re: rustoleum
I saw online you use luke 60/40 but didn't know forsure
#18 |
Re: rustoleum
I just did my truck bed, first used rustoleum rust treatment for any minor surface rust, then light primer, then the rustoleum truck bed coating. That stuff works terrific, and at a mere fraction of the costs of other stuff. Like 40 bucks at walmart. I was surprised at how tuff it is. NOT like spray paint. Goes on like your spreading tar or oil. It paints great though. Very hard finish. You can't scratch it or dig your nails into it. Hard like stone!! As far as spraypaint, rustoleum is great. The key is a clean surface, let primer dry fully, and DONT spray on too heavy!! Use multiple light coats.
#19 |
Re: rustoleum
Wow, that came out really nice!!!
#20 |
Re: rustoleum
I'm now scared to roll it on cause it seems no one does that. I want it to turn out well enough I could sell it after if I didn't like it.
#21 |
Re: rustoleum
#22 |
#23 | |
Re: rustoleum
Do some Googling for the "$50 paint job" (The Thread that started it all - look for the orange Charger).
#24 |
Re: rustoleum
I finished the body work on the other half of the truck and painted it all white. I'm going to wait till all the body work is finished to paint the color coat, with the white stripe masked off. First just using white paint all over to seal up the primer and bondo.
The roller method is excellent for getting in between the bed and cab without having to remove the bed. The 4" brush fits perfectly. With an extention on the roller I could get waaaaay in there. The rustoleum goes on SO much better and flatter than the sherwin-williams All-Surface paint. So that's two coats of white rustoleum, thinned to roughly 70/30 with mineral spirits (paint thinner) and with a splash of Penetrol paint conditioner (helps it lay smooth, but in my experiments it didn't make a whole big difference, but I bought it already and any tiny bit helps). No sanding yet. [edit] Holy huge images, batman!! sorry for stretching the page guys... |
#25 |
78K & 79C Jimmys
Re: rustoleum
I did my 78 "roll on",with no thinning out,fire red.
It's got some peel,runs,but it's better protected. And may get another coat this year http://67-72chevytrucks.com/vboard/s...=421767&page=9
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
