Old 04-23-2015, 09:18 PM   #1
jerry1194
65 gmc rear end
I have 1965 GMCshort bed,originally 6 cylinder,3 spd on the column.My question is if I drop a 350 crate motor in it I was told I need to change out my rear end,it has a ten bolt in it now and I want to keep the 3spd trans will the original trans and rear end work with the 350?
jerry1194 is offline   Reply With Quote
Old 04-23-2015, 10:49 PM   #2
siggyfreud
siggyfreud's Avatar
Aside from wanting to change gear ratios you shouldn't have to do anything to the rear end itself. It likely won't know or care what engine is up there unless it's putting out massive power that might challenge or break the rear.
siggyfreud is offline   Reply With Quote
Old 04-24-2015, 02:02 AM   #3
Captainfab
60-66 Nut
Re: 65 gmc rear end
Your rear end will be the Dana 44. As long as your 350 is stock to moderately built and you aren't running wide and or stickey tires, it will live quite a long time. As for the 3 speed, I don't have any experience with those. But just as with the rear end, it is how much power you are putting thru it and how you drive it.
Old 04-24-2015, 08:01 AM   #4
duallyjams
duallyjams's Avatar
Re: 65 gmc rear end
bell housing, trans and rear will work
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-24-2015, 10:03 AM   #5
TJ's Chevy
TJ's Chevy's Avatar
Re: 65 gmc rear end
A whopping 290 hp ain't gonna hurt that rear. What's wrong with the motor you have?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-24-2015, 01:03 PM   #6
frankslagoon
Re: 65 gmc rear end
your gona hate that 3 sp. good news is it take about 30 minutes to change em. if ya drive like an old man.well, not like this old man. and never try to get into 1st. gear till your stopped you'll be ok but non-syncro trannys are not much fun.
frankslagoon is offline   Reply With Quote
Old 04-25-2015, 11:06 PM   #7
jerry1194
Re: 65 gmc rear end
Thanks for all the replies,it answered my question.To answer some question that were asked, the original six cylinder is locked up and im getting a good deal on a 350 crate. I have plans on making this a driver on a budget but not truck that's jury rigged.A friend gave me 3spd trans that is synchronized so that's another reason im going with that.Im going to spend a lot of money on body and paint so other major fixes are going have to be updated later.
Old 04-25-2015, 11:21 PM   #8
bowtied4life
bowtied4life's Avatar
Re: 65 gmc rear end
Sounds to me like you have a good plan going, the rear end and trans will be fine unless you plan on putting massive power to it. Good luck with your project.
1965 GMC LWB 383/700R4
1947 Fleetmaster Coupe Supercharged
1955 Chevy Bel Air LS3/6l90e
2012 GMC Denali 2500HD
bowtied4life is offline   Reply With Quote
