04-24-2015, 04:44 PM | #1 |
who has poly body mounts besides LMC?
Who sells the poly mounts for our blazers (4WD) that has the correct size hardware? I have heard/searched that the poly mounts are a little bit different size. Is this true?
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
04-24-2015, 09:35 PM | #2 |
Re: who has poly body mounts besides LMC?
I have Energy Suspension cab and body mount kit on mine. Was one of the first things I replaced on my blazer.
04-25-2015, 07:33 PM | #3 |
I also have the energy suspension set. I bought the kit from summit racing. Also bought the transfer case kits too.
Kirk 72 Blazer CST 4wd highlander |
04-26-2015, 12:01 AM | #4 |
Do you happen to have the part #'s from your invoice handy? Did they come with the bolts or did you have to source those yourself?
04-26-2015, 02:30 AM | #5 |
Kits don't come with bolts. Had to get bolts from the hardware store for the ones that had to be cut to remove.
04-27-2015, 01:50 AM | #6 |
These are the summit part numbers that I bought. Good stuff for the money. I haven't replaced them yet but lmc sells all the bolts. Of course a local hardware store will sell carriage bolts and be much cheaper. If the bolts come off without breaking just take them down and match them up. They will be different lengths so label them when you pull them.
Part#: 3.4110g Part#: ENS-3-1107R Part#: ENS-3-1106R
04-27-2015, 08:12 AM | #7 |
Prothane makes the mounts as well, I bought a set, they look good
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
04-27-2015, 11:00 PM | #8 |
Thanks guys.
