Old 04-24-2015, 09:15 PM   #1
iceship
LS swap power steering
Any of you guys running your old gm pump... My 6.0 didn't come with a power steering pump. So I'm keeping it low budget...
iceship is offline   Reply With Quote
Old 04-25-2015, 07:02 AM   #2
Alex41
Re: LS swap power steering
You can't run an old school pump on the new LS based engines...they just won't bolt up. You can, however, use the factory LS pump and the lines will bolt up to it from the factory steering box.
Alex41 is offline   Reply With Quote
Old 04-25-2015, 09:50 AM   #3
mattcrp1
mattcrp1's Avatar
To plumb my steering system up I used the 2002 lsx p/s pump with the '76 regulator from the old pump. This allowed the '76 p/s pressure line to bolt up to the 2002 pump body. Check out the build thread in my sig, I believe there is a pic in there of what I did.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 04-25-2015, 07:22 PM   #4
iceship
Ok thanks...
Old 04-26-2015, 06:28 PM   #5
iceship
Looking on the s10 forums and they are using 350 pumps and it lines up.... Go figure
Old 04-26-2015, 07:16 PM   #6
MalibuSSwagon
The LS truck engines do use the same Saginaw pump as our trucks, the only issue you may run into is the reservoir is not the same and may not clear the engine bracket. Otherwise it should bolt up.
MalibuSSwagon is offline   Reply With Quote
Old 04-27-2015, 10:17 PM   #7
iceship
My bad I put out the wrong info.. It was a power steering pump from a 93-97 s10 and it has to be from a 4.3l.. I looked at the s10 forum ls swap
