Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-25-2015, 12:45 AM   #1
BigDan3131
BigDan3131's Avatar
Question Check Valves
I plan to have a local company build a fuel cell to my specs that if I were to use the whole space minus one inch for air it would hold 32 gallons, then I decided since I'm having it built I would have a tank within a tank. So subtracting a small area the main part will hold just over 27 gallons and the smaller will hold 5 gallons.
Now the check valve would be installed after a fuel shut off to keep the main from filling up the the smaller tank. Outlet size will be -10 on both tank halves.
Have any of you used check valves like I plan to do?
The reason I plan to have the two tanks is so either I can keep the smaller as a reserve on long drives or to put high octane fuel in it for when I want to up my boost level for some fun.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
