Old 04-25-2015, 04:09 AM   #1
macdodd
RPMs
I'm running about 3k at 72mph,,,is that ok or will it hurt the engine. Running a 350/305 heads. What would the red line be or close to it? Its a '69 Chevy short bed C-10.
macdodd is offline   Reply With Quote
Old 04-25-2015, 08:40 AM   #2
jessemthompson
Re: RPMs
That depends on a lot of factors. I would say 4500-5000 to be safe
jessemthompson is offline   Reply With Quote
Old 04-25-2015, 09:04 AM   #3
Swar
Swar's Avatar
Re: RPMs
I have a 350, 4 speed manual. Mine runs 3k at 60mph. Been driving it a long time, never had any issues.
Small blocks can rev out no problem, but it's better for the engine to change rpm rather than stay at one for a long time.
Swar is offline   Reply With Quote
Old 04-25-2015, 09:22 AM   #4
macdodd
Re: RPMs
I'm running P235 60r 15s on it,,,,was thinking about changing the rearend gears,,,but if the speed vs rpms sound ok,,,I'll leave it alone,,,,might put equal lock rear in it,,, it has a 3 speed auto in it. I just want to be able to drive it on the interstate roads sometime, like to the mountains from Florida,,,without burning something up.
Old 04-25-2015, 09:38 AM   #5
Swar
Swar's Avatar
Re: RPMs
Yea if you're looking to travel with it, the lower you can get the rpm in top gear, the better. An auto with OD would be ideal.
Old 04-25-2015, 10:05 AM   #6
Boog
laying low
Boog's Avatar
Re: RPMs
3g at 72 mph is more than i like for sustained periods of time. 22 to 2500 rpm is more to my liking. And wont use near as much fuel either.
235/ 60 tires are rather short at around 26". You could switch to a taller tire like a 255/70 at around 29" that will make a good reduction in highway rpm, change rear gear ratio(more expensive) or install od tranny( still more expensive). Or just drive slower and no body wants to do that 😉
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-25-2015, 01:02 PM   #7
macdodd
Re: RPMs
LOL,,,,well,,,I wouldn't be on the interstate all the time,,,,,the truck is lowered all the way around,,,so can't go to much higher on the tires. Gonna have nito shocks put on it to control the bottoming out.
Old 04-25-2015, 01:42 PM   #8
TBONE1964
Cluster King
TBONE1964's Avatar
Re: RPMs
Here is the simple fact. Engines wear and the faster they spin, the faster they wear. Excessive RPM's will accelerate the time of death on any engine.
2K at 70 MPH will live much longer than 3K at 70.
Nice truck by the way.
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 04-25-2015, 02:25 PM   #9
leftybass209
leftybass209's Avatar
Re: RPMs
Take care,
Tom
This is pretty much the no frills way of putting it. Reduce your RPM's and increase your engine longevity. So when you ask, are you going to hurt something? YES, you are hurting the longevity of the engine. If you don't have roller components, you are also drastically increasing wear on your valvetrain.
leftybass209 is offline   Reply With Quote
Old 04-28-2015, 11:38 AM   #10
burnin oil
Re: RPMs
Low RPMs wont always decrease wear. If it is lugging a lot the cylinder pressures are higher than a motor that is at low throttle and high RPMs. Pretty much every sb I have seen has passed 100k miles without major issues no matter if it came in a truck with 4.56s or a car with 2.73s. It also takes enough RPMs to properly drive accessories like the water pump and power steering pump. A lot of guys used to get themselves in trouble running 3.07s and adding an OD trans. Best mileage and longevity happen at a happy medium. 3k RPMs is high but shouldn't have a problem lasting a long time. I run my truck down the interstate at 75 MPH for hours on end with 4.10 gears and no OD. If the truck has a 4v carb try to adjust it so it is only on the primaries at 3k RPM. I have been around a lot of Qjets that were on the secondaries when on the interstate.
burnin oil is offline   Reply With Quote
Old 04-28-2015, 12:52 PM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: RPMs
You guys do remember that these trucks ran at those RPM's for many years when they first came on the scene. It was normal to cruise with a 350 cubic inch engine at highway speeds close to 3,000 RPM's when these trucks were built. Nowadays we are all conditioned to low RPM cruising speeds with newfangled fuel injected engines and super duper overdrive transmissions that put our cruising RPM's almost below 2,000 RPM's.
Having a rig run at 3 grand for short periods of time at highway speeds isn't going to hurt that 350 in the least (maybe robbed of power with the 305 heads ). It will hit you in the wallet though. Like burnin oil said... the secondaries will probably be cracked and suck up some fuel.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-28-2015, 01:49 PM   #12
GRX
GRX's Avatar
Re: RPMs
Well said Gary!
Oil pressure at 3k rpm is what I would be most concerned with. You might be amazed at the distinctly different wear patterns on internals between an engine which cruises at highway speeds consistently, and one which idles at the job site all day.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 04-28-2015, 06:15 PM   #13
ole dollor
ole dollor's Avatar
Re: RPMs
how big is your gas budget , and how far are the gas stops apart....lol
ole dollor is offline   Reply With Quote
Old 04-28-2015, 10:47 PM   #14
Boog
laying low
Boog's Avatar
Re: RPMs
Real good looking truck Macdodd. Using the Richmond gear calculator it puts your rear gear at around a 3.42 for a 27" tall tire. If so it is a good all around ratio. It may just be the angle of the pic but those rear tires sure look larger than 235/60/15.
Boog
primer is finer
Old 04-29-2015, 12:22 AM   #15
BruthaMan
US Army Veteran
BruthaMan's Avatar
Re: RPMs
I drove a four hundred mile trip almost every week last year, working on a remote project.
Two hundred miles up, two hundred back at the end of the week. First few trips, I tried to drive at 70 mph, but was around 3400 rpm.
I eventually backed it down to 60 mph which was right around 3000 rpm. I have 4:10 rear gears. Fun from stop light to stop light, but a screamer on the highway.
Truck did fine, but I did have to replace the water pump. Changed the oil meticulously every four weeks. Mobile One and added ZDDP plus. Some say isn't necessary with synthetic, but I wanted all the insurance I could get.
Would also run a little Marvels Mystery oil in the gas once a month too.
BruthaMan is offline   Reply With Quote
Old 04-29-2015, 02:19 AM   #16
jhwkns
Registered Cruiser
jhwkns's Avatar
Re: RPMs
Mine runs 73 mph a 3,000 rpm. That's a .373 gear and 275/60/15 tires. I road trip with it frequently. It's never been a problem.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 04-29-2015, 10:27 AM   #17
Kimjongthrill
Kimjongthrill's Avatar
Re: RPMs
@boog i was thinking the same thing about the rear tires, maybe 275/50 is what they are?
what about that little guy?
That little guy??!! I wouldn't worry about that little guy
Kimjongthrill is offline   Reply With Quote
Old 05-09-2015, 07:39 AM   #18
macdodd
Re: RPMs
Well,,,,I'm gonna run for awhile without changing rear end gears and see what happens. Like afew have said in here,,,just not used to the high rpms of the older engine and the noise,,,LOL. Very true,,,we've got used to the modern engines and no noise,,,LOL. Any suggestions on oil? Gonna change it soon, I used a oil additive and it really helped quiet the enging down,,,seemed to up the oil pressure too. Thanks for all the input,,,,been years since I've had a vehicle like this,,,,LOL,,,,I love it,,,,,be safe out there,,,,,Bill
