Old 04-25-2015, 12:08 PM   #1
mjgord51
Need Help w/stock rims
I am wanting to use original 15" 6 lug rims on my 68 C10. It has drums on back & frts have disc from what I have found from spindle casting #s there from a 92-02 5 lug truck, the disc are after market with no ID #s. ***I would like to learn how to measure from what point to what point for stock rim DIA. and all of the other measurements needed for ID ing a stock rim.*** Thanks in advance for the help. mjgord51
mjgord51 is offline   Reply With Quote
Old 04-25-2015, 03:22 PM   #2
cdowns
cdowns's Avatar
Re: Need Help w/stock rims
original stock rims will not work on those disc brakes// you r going to need 73 or newer rims
Old 04-25-2015, 08:34 PM   #3
Hutch
Hutch's Avatar
To go back to stock 15 in rims you will need to switch the front to a 71 72 5 lug disc brake spindles and rotors. It may be easier to get a whole crossmember to switch out with your current one. Then the 15 in rims in the front will need to be also from a 71 or 72 To clear the disc. Calipers you can identify the stock 15 in rims for a disc brake truck as the ones with four nubs to hold the hubcap on the earlier drum brake wheels only have three nubs.
You can do a search on the forum to find a lot of info on this subjct as it can be pretty confusing. You really need to have the same lug pattern on the front and rear so you will be able to carry one spare tire to fit all four corners.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
