Old 04-25-2015, 03:37 PM   #1
merlin3
intake leaking
i just noticed the drivers front of the intake leaking antifreeze.I installed a new Edlebrock air gap with new gaskets,torqued the bolts to the proper sequence and it leaks.aside from the gaskets,would you guys replace the intake as well to be on the safe side? [509 merlin3 with iron heads] it is avery small amount of antifreeze.thanks for the help
merlin3 is offline   Reply With Quote
Old 04-25-2015, 03:59 PM   #2
leftybass209
leftybass209's Avatar
Re: intake leaking
Could it be leaking from the front couple bolts, or any water plugs you have. Those all could use some sealant or thread tape.
leftybass209 is offline   Reply With Quote
Old 04-25-2015, 04:52 PM   #3
merlin3
Re: intake leaking
thanks lefty bass i watched it closely and when motor is shut down it leaks right at the edge of intake and gasket next to head,nothing else near it is leaking.
Old 04-25-2015, 04:56 PM   #4
leftybass209
Re: intake leaking
Did you use a front and rear gasket, or a bead of sealant around there. I've had much better luck with the sealant, rather than the gaskets. Could it be that your block or heads were shaved a little?
Old 04-25-2015, 05:18 PM   #5
merlin3
Re: intake leaking
the motor was running fine,no leaks when it was taken out before i bought it.i did not use the front and rear gaskets i used sealant but it is not leaking there it is leaking on drivers side top front edge were it meets the head about 3 inches back from the front of motor.
Old 04-25-2015, 05:26 PM   #6
merlin3
Re: intake leaking
here is a photo
Old 04-25-2015, 06:17 PM   #7
enaberif
Re: intake leaking
I would say either warped flange on the intake or warped surface on the head. Take a straight edge and check.
enaberif is offline   Reply With Quote
Old 04-25-2015, 06:47 PM   #8
hamjet
hamjet's Avatar
Re: intake leaking
Keep an eye on your oil to make sure its not leaking into the intake valley also..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 04-26-2015, 06:48 AM   #9
merlin3
Re: intake leaking
thanks i did check the oil, seems fine
Old 04-26-2015, 08:21 AM   #10
volksworld
Re: intake leaking
maybe try a different brand of gasket or some rtv around that water passage...
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
