![]() Join Date: Jun 2006
Emergency Brake
So I was looking at my emergency brake hardware and I'm wondering if I can still use it when I switch from the Powerglide to the 4L80E. Will it be adjustable enough when I move the crossmember back for the 80E?
1965 GMC 3/4 ton longbed, it had the 305E and Powerglide until the motor went bye bye.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Emergency Brake
Subscribed.
![]() Join Date: May 2007
Re: Emergency Brake
check the faq section at the top great info on everything
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Moderator
Re: Emergency Brake
I like Chief's idea:
http://67-72chevytrucks.com/vboard/s...46&postcount=4
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Emergency Brake
I would change it over to the '66-'72 style which has no crossmember for the e-brake, just cables.
