04-26-2015, 02:20 PM | #1 |
How low can you go?
Interested in seeing how far a 79 short box can go without having to cut into the bed. Riding on stock height wheels.
Any pics? |
04-26-2015, 02:54 PM | #2 |
Re: How low can you go?
I've just measured up for flipping the axle on mine (@5-6") and the chassis rails will need notching although the diff shouldn't hit the bed. Shock stiffness will also be a factor. I must confess to having no idea of stock tyre size as mine has been fitted with 31 x 10.50 -15's by a previous owner.
04-26-2015, 03:05 PM | #3 |
Thanks J1mmy. I am looking at a 79 and it's already lowered on rallies, looks to be stock size rubber. I am thinking it would pretty good bagged, but if I get a truck, I need to make sure the bed floor isn't adjusted.
04-26-2015, 03:09 PM | #4 |
I love my 79 - it's rough n ready but a rarer sight over here than the earlier and later model trucks. How has it been lowered up to this point? Leaf removal? Shackles?
Edit - I'm guessing that stock tyre size is 235 75 15 as per most 1/2 tons of the era? |
04-26-2015, 03:11 PM | #5 |
It was done with a flip kit in the rear and spindles up front 3/4
04-26-2015, 03:13 PM | #6 |
Flip kit only did 4"? Hmmmm...got a pic or link?
04-26-2015, 03:18 PM | #7 |
Not with me. On the phone shopping with the missus...
04-26-2015, 03:53 PM | #8 |
04-27-2015, 12:25 AM | #9 |
It wasn't so bad.
Any suggestions on a budget air bag set up for a 79? |
04-27-2015, 12:48 AM | #10 |
Actually the standard tire size for 1/2 tons was H78-15 which to the younger crowd is a 225R75-15. The 235R75-15 would be an L78-15 which was optional
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
04-27-2015, 05:06 PM | #11 |
Happy to be here
Look at member Jwalls truck. He has before and after of static and bagged with just a C notch out back.
04-27-2015, 05:19 PM | #12 |
Frequent Flyer
This is with a 27.5" rear tire size
This is the absolute lowest you can go without the rearend hitting the bed floor. Has a bolt in c-notch with bagged suspension. Before bags with static drop & same c-notch. |
04-27-2015, 05:26 PM | #13 |
Thank you!!! I think if I get it I'll leave it where it's at. If I go any lower I'll bag it if I can piece together a set up.
That truck looks beautiful by the way |
