bolt sizes
hi all,looking for a couple of bolt sizes!battery box,w/washer jug bracket and horn! i believe most of the other front sheet metal is 5/16x18x3/4.thanks for any help...dan
Re: bolt sizes
Battery box is same as the front sheetmetal. I can check horn and washer bottle tonight. Washer bottle I believe is same as battery box and front sheetmetal and the horn is two smaller screws with bolt heads. I'm thinking 1/4" screws w/bolt heads.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Re: bolt sizes
Just took mine apart Saturday. Battery box, washer jug bracket, fender bolts are all 5/16 x 18 x 3/4.
If you don't like this ![]() |
![]() Join Date: Aug 2013
Re: bolt sizes
just mocked mine up, all the. front metal is all the same!!! only the hood and rear inner fender attachment is different
Re: bolt sizes
thanks for the help guys!
