Old 04-26-2015, 08:07 PM   #1
Malamute
Malamute's Avatar
Lower ball joint dust boot help
I pressed the lower ball joints in today with no problem but I cannot get the dust boot seated all the way for the life of me. I tried using one of the rings from the press and that wouldn't work either. I really don't want to tear one and wondered if a little grease on them would help.
The uppers are no problem since they are two piece. I searched but couldn't find anything for this specific problem. Any help would be appreciated.
Malamute is offline   Reply With Quote
Old 04-26-2015, 08:27 PM   #2
hugger6933
Re: Lower ball joint dust boot help
Put it on and not worry about it. It can't go anywhere once the spindle is back on. Just don't over pump it up with grease when you grease your chassis. Jim
hugger6933 is offline   Reply With Quote
Old 04-26-2015, 08:36 PM   #3
Malamute
Malamute's Avatar
Even if it's not close to the CA? That was my worry that grease wouldn't stay in, but I'm guessing with the spindle holding it down it will be OK?
Old 04-28-2015, 10:14 AM   #4
KyleSeal
KyleSeal's Avatar
Make sure you have the correct boot for the bottom and the top, I had it backwards when I did mine but was able to fix in time.
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 04-28-2015, 10:35 AM   #5
michael bustamante
michael bustamante's Avatar
is the boot not sliding all the way down the ball joint threaded shaft? the boot may be too small
1967custom
michael bustamante is offline   Reply With Quote
Old 04-28-2015, 12:34 PM   #6
Nochance
i usually take two pairs of channel lock pliers and hold the boot down on one side and work my way around with the other pair. One other thing is there should be a small channel cut out on the bottom of the boot that needs to be pointed towards the coil spring. Its for when you do over grease the joint the excess doesn't get squirted on the brakes.
good luck
Nochance is offline   Reply With Quote
Old 04-28-2015, 10:48 PM   #7
Malamute
Malamute's Avatar
Thanks guys. They were in the box with the ball joints so I assume they are the right ones. And yes, I have the notch to the inside. I haven't tried them again, once I'm done with a few other things I'll go back and try them again.
Old 04-28-2015, 10:54 PM   #8
enaberif
Toss them in a bit of hot water to help loosen them up and try again.
enaberif is offline   Reply With Quote
Old 04-28-2015, 11:01 PM   #9
Malamute
Malamute's Avatar
Thanks. I almost thought about throwing them in some warm, soapy water but I didn't know if the residue would cause problems down the road. I think they would go with a surfactant on them.
