Wiper arm and blade questions
I have a set of new reproduction wiper arms and blades on my burb which are just junk-- right out of the box. Would be fine for show only but not for use in a rainstorm. I am sure I can find a set of nice original arms and polish them up but what about blades? I think TRICO RB 12 blades may be correct and they show up on Ebay all the time as NOS, but 2 things, they also fit early Corvettes and sell for Corvette prices. Also the rubber on them are usually pretty dried out. It does rain in WASHINGTON state once in a while, so I would like good wipers. Thanks, Jim
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Wiper arm and blade questions
You can replace the rubber wiper by buying cheap leftover wipers at the autoparts store and transferring them over to your wiper. Most stores have wipers that didn't sell. You can cut to length.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Good idea. I will be on the search for some good used arms and blades to rework. J
Original blades were 13", but the 12" would probably work.
Ive tried to source an original Trico part #, but have been unsuccessful so far.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
![]() Join Date: Feb 2014
Met a guy at the show in Carlisle, PA that was offering new (Staineless) arms and blades for $40 a pair, he specializes in classic car and truck wiper arms & blades. Not sure if they were NOS, but looked alot like the OE.
Heres his info if your interested: msharrell1957@gmail.com |
I bought the ones from LMC truck and they are nice. Before that I had a set from ClassicParts, but they were cheap and the passenger side one would randomly fall off when in use, scratching my glass up.
As for the rubber blades, I just go to the auto parts store, buy ones that are too big and cut them down to size, works fine.
1963 Chevrolet C10 Stepside 1972 Pontiac GTO 1998 Dodge Viper GTS 1999 Jeep Cherokee XJ 2018 Chevy Camaro ZL1-1LE It's never too early to beef up my obituary |
TRICO model 73 or 51. These were used on many vehicles. See this page
http://www.dacoglu.com/desotocd/14_b...per%20arms.pdf This might also work ![]() http://www.oreillyauto.com/site/c/de...3299&ppt=C0047 Hope this helps! |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I've always just stopped at my local auto parts store and picked up a set of 13" wiper refills. As for the wiper arms themselves I have always just used original arms. I think the springs in them loose a little tension and don't hug the windshield like they should.
#9 | |
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 04-28-2015 at 11:10 AM. |
I also buy longer blades and cut them down to fit. Also you can open up the arm and change the springs with springs from your local hardware store to make them push down better. Works for me.
past trucks: 1980 C-10 Silverado SWB 1961 C-10 custom cab LWB 1966 C-10 custom cab LWB |
Does anyone else know if there is an aftermarket arm that has the "J" hook at the end to use the new style clip in wipers? I thought about making some, but figured it would be good to change the arm at the same time...
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
Who Me?
I used cut to fit blades on mine and they worked good.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#13 |
Found NOS 13" Trico blades, now just need arms. J
#14 |
So you replaced your wiper arm springs? Any pics? Also what springs did you buy and how hard was the swap? Mine are skipping so assume they need new ones
#15 |
Whats the part # and have you tried them on yet?
