04-27-2015, 12:15 AM | #1 |
pic request:4x4 shifter bolt mounting/shims
1971 k10 chassis. I mounted the shifter on the transfer case,and it has room to wiggle side to side a decent amount. Doesn't seem right. It has the large bolt with a thin washer,that goes through the shifted lever and threads into transfercase.no other shims or washers.
I am looking for pics of where the shifter bolts to the transfer case to see if I have this right.doesn't seem right....
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
04-27-2015, 12:22 AM | #2 |
Re: pic request:4x4 shifter bolt mounting/shims
http://67-72chevytrucks.com/vboard/s...34&postcount=3
http://67-72chevytrucks.com/vboard/s...d.php?t=630022
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
