08-31-2003, 04:53 PM | #1 |
Sisyphus was my mentor!
Is there a rad-shroud for a straight 6???????
Is there such a thing as a rad shroud for the straight six? If so, does any body have one?
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
08-31-2003, 05:05 PM | #2 |
When I had the six in my stepside, it only had a plate that mounted on top of the radiator and was about a foot or so wide. It's only purpose that I could see was to keep you from getting hit by the fan. Don't know if they actually ever made a functional shroud or not
Anyone else know? Oh and I still have it somewhere in all my conversion junk pile
1970 C-10 LWB 1998 Jeep Wrangled TJ 2009 Honda VTX 1300 2013 Buick Enclave |
08-31-2003, 05:22 PM | #3 |
metal plate is it,moreof a guard than anything else
08-31-2003, 05:44 PM | #4 |
I have a small block shroud and 18" electric fan on my 322 eh 292 inline
Rest in Peace Ed. Thanks for all the good times. |
08-31-2003, 06:11 PM | #5 |
I've got a 72 4x4 with the 250 inline and all it has is the metal top fan shroud. I've wondered the same thing as in is there a full fan shroud for a straight six?
Josh
72Chevy swb 4x4 71GMC swb 2x4 |
08-31-2003, 06:52 PM | #6 |
Born Psycho
the one 71elect shows is to only type i've ever seen. if thats what you're looking for, i have one to sell. $20.00 + mail
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
08-31-2003, 07:18 PM | #7 |
Inline 69
all i have on my inline 6, is the metal plate like "71elect",,,,,no shroud,i thought last owner took it off,,,jeff
08-31-2003, 07:48 PM | #8 |
my 67 292 had a complete shroud when I got it. I'll check with the PO to see if he installed it but it looks original to me.
2004 Kawasaki KLR Always looking for a cheap driver |
08-31-2003, 08:14 PM | #9 |
all i have is the metal plate on top too - I just thought that it would be an ez cooling upgrade. Will any other shroud fit? A BB shroud? A SB shroud? With air? Without air? I know the six if the first thing people throw away with our trucks BUT I cant afford that just yet so I'd like to do a few upgrades to my six & make it more reliable... I dont think I want an elec. fan - I'd like to keep the stock fan OR put a clutch fan on with a shroud... Anybody know what works?
08-31-2003, 08:23 PM | #10 |
Are you having cooling problems?
08-31-2003, 08:25 PM | #11 |
My 70 GMC had a make-shift shroud on it when I bought it. I saw from the labels on it that it was from a vehicle equipped with a V-8. It has screws in each side as if it were made to part. There's plenty of clearance, and it DOES make a difference in the amount of air pulled thru when just at idle. I'll check tomorrow and get what info I can off it.
Hope this might help some. Billy G
My FAMOUS LAST WORDS...."Ima Gonna!!" - 1970 GMC 1500 swb/step 250 I-6 3 spd - "The GEM" - 1976 Chev Scotsdale swb/step 350/350 - "The JEWEL" - 1982 Chev C-10 swb/step 250 I-6 3 spd - - 2001 Chev Silverado LT - |
08-31-2003, 09:50 PM | #12 |
it does run a bit hot BUT I know that the carb has seen betterdays & the timing is set weird... I'll get those fixed soon enough. I think a shroud would be a good addition to my combo & who knows, if I hot-rod my 6, it'll take all it can to cool it. My experience has been with the 327 in my belair that 3 cores, 160stat, a clutchfan + a shroud works pretty good in hot HUMID weather upto +36C (about 98F) IF i dont push it.. i'm just thinking that the 6 with a 2core rad, no shoud & a regular fan may need a little help - esp. with 3.70 rear gears. thanks to all for your shroud suggestions & I'd like to hear about any L6 shoud combos!
08-31-2003, 10:25 PM | #13 |
its all about the +6 inches
The finger protector is all they came with. I doubt any other stock shroud will fit becouse of the added length of an inline engine.
09-01-2003, 02:53 PM | #14 |
"Trucks with Class"
SB fits!
SB shroud fits real good with a wide SB radiator. Just move the top and bottom mounts to the V8 position...better radiator and a shroud make a lot of difference. I had one stock 250 with this combination from GM. It was listed as a HD cooling option in a fleet or special order truck. You can see a piece of the one I did here...maybe.
09-01-2003, 04:41 PM | #15 |
Intresting, so it was available...just not common.
