Old 04-27-2015, 09:46 AM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
1 Man - Installing and/or Removing Hood.
Any ideas on One Man Installing and/or Removing Hood?
I don't have an engine puller.
66 C20 Service Truck:
Old 04-27-2015, 10:05 AM   #2
63longfleet
Re: 1 Man - Installing and/or Removing Hood.
Ive done it with 2 long prop rods on a couple of cars before, should be the same process
63longfleet is offline   Reply With Quote
Old 04-27-2015, 10:43 AM   #3
Lowl!f3
Lowl!f3's Avatar
Wait. For help
1965 C10 Project
Lowl!f3 is offline   Reply With Quote
Old 04-27-2015, 11:07 AM   #4
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I did it....used the forks of my tractor and that propped the hood, let is slide off the brackets and then lowered it...then got underneath and man handled it off. lol I've also done it when I propped the hood with my head and let it fall on me.....the 1st way is a tad less painful though.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-27-2015, 11:17 AM   #5
Free Candy Inside
Maybe use a ratchet strap on each corner and raise it up then back from under it??
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Free Candy Inside is offline   Reply With Quote
Old 04-27-2015, 12:01 PM   #6
1963c-10
1963c-10's Avatar
Originally Posted by Lowl!f3 View Post
Wait. For help
yeah, this has always been my method too. Cabs & beds no problem....but the hoods especially when painted I wait and get help on.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-27-2015, 12:38 PM   #7
61K10
61K10's Avatar
this is how i did mine. had a few tie-downs---
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-27-2015, 03:50 PM   #8
LostMy65
LostMy65's Avatar
I think I'm going to try this.
The pictures helped.
Thank you.
And thanks to the other's too.
Old 04-27-2015, 04:01 PM   #9
markeb01
Senior Enthusiast
markeb01's Avatar
I did mine in a similar fashion with a cherry picker. If I didn't have that, I'd bolt substantial brackets to the ceiling joists and lift the hood with ratchet straps., and as noted above back the truck out from under. Just be careful when it comes time to release the tension. I use ratchet straps for all kinds of things, including hood spring installation.
We don't have any help readily available, so waiting isn't much of an option. I figure out an engineering solution rather than stop progress.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-27-2015, 04:52 PM   #10
joe dirt
joe dirt's Avatar
suppose I could come by and help you...im going to be removing my hood soon so you can come help me...lol
joe dirt is offline   Reply With Quote
Old 04-27-2015, 11:52 PM   #11
argonaut
argonaut's Avatar
In a pinch I put some rags on the cowl, unbolted one side at a time. Then just reached under the hood at the center and lifted it overhead. It was pretty darn heavy though. Cherry picker and a few straps makes it easy.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 04-28-2015, 07:14 PM   #12
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
61K10 has the right idea.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 04-28-2015, 10:14 PM   #13
dougf
dougf's Avatar
I have done it, but I'm 6'3" and 245 which helps but I usually just walk inside and drag the wife out to help.
dougf is offline   Reply With Quote
Old 04-28-2015, 10:50 PM   #14
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
this doesn't help much... I am just jealous of the clamp they got to use at the factory.... it hooks under the front lip, and then has a rest in the center....
I have found that I can get a hood off by myself with out scratching the paint, but there is pretty much no way to put it on with out tearing stuff up!
*** also check out that cool tire stand.. I need one of those for my 4X4!
Old 04-28-2015, 11:22 PM   #15
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Im about 15 minutes and a six pack away.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 04-29-2015, 12:48 AM   #16
joe dirt
joe dirt's Avatar
Same here...im in gresham boring area
Old 05-03-2015, 10:58 PM   #17
LostMy65
LostMy65's Avatar
Thanks guys.
I was able to get help today.
I think I'm going to go buy an engine hoist for next time.
I'll need it for future projects anyway.
Old 05-03-2015, 11:15 PM   #18
brap999
brap999's Avatar
The only way I have ever been able to do it alone is with an engine hoist. It's the single best tool i own, comes in handy for so many things.
1963 Chevrolet C10 Stepside
1972 Pontiac GTO
1998 Dodge Viper GTS
1999 Jeep Cherokee XJ
2018 Chevy Camaro ZL1-1LE
It's never too early to beef up my obituary
brap999 is offline   Reply With Quote
Old 05-03-2015, 11:55 PM   #19
luvbowties
luvbowties's Avatar
Red face Re: 1 Man - Installing and/or Removing Hood.
Lots of people might be surprised how many engines can be removed with the hood left in place IF you have a cherry-picker. Surely surprised me 1st time I saw a mechanic, helping me, remove a sbc from a 1965 C10 I was changing engines in--and never touched a hood hinge bolt! Left the tranny in place too, held in place by a crossbar under 'bell-housing' bolts[extended forward with nuts holding them] w/ends of crossbar supported by the frame.
Radiator stayed bolted up too.
So, I learned a lot on that day!
Sam
luvbowties is offline   Reply With Quote
Old 05-04-2015, 12:06 AM   #20
luvbowties
luvbowties's Avatar
Cool Re: 1 Man - Installing and/or Removing Hood.
...and so it's time to yell for the good wife to come and help and [over-] pay her upkeep...
Sam
Old 05-04-2015, 12:19 AM   #21
luvbowties
luvbowties's Avatar
Thumbs up Re: 1 Man - Installing and/or Removing Hood.
Got a buddy with a Harbor Frt. cherry picker that he modified with one of their air-operated valve-lifts--talk about charm on top of charm! It may be air-over-hydraulic, I just can't quite recall. (My doc says my memory problems and shortness of breath--which he abbreviates as "sob"--is not caused by my age, but by my blowing out all the birthday candles.)
s
