Old 04-27-2015, 04:34 PM   #1
HappyHooligan
HappyHooligan's Avatar
Clutch Pedal Height
Finally picked up my new ride this weekend, but have a Clutch Pedal Issue.
When released the pedal comes almost 6 inches higher than the brake pedal.
Engages and disengages fine for shifting, at what seems like the right place. but then pedal keeps coming up. more than doubling the distance from floor.
I am sure I have seen a post on this already but cant find it now that I need the info.
Any Help is appreciated.
Hooligan
HappyHooligan is offline   Reply With Quote
Old 04-27-2015, 05:03 PM   #2
Mackie
Mackie's Avatar
Re: Clutch Pedal Height
Assuming this is a mechanical linkage clutch: The clutch pedal should be just about level with the brake pedal, maybe a little higher. Mine used to be quite high until I re-bent the bracket that holds the return stop bumper under the dash. Look there.
`63 C-10 Shortwide
Roller 305 LT1 cam, Eddy 500
T5
Mackie is offline   Reply With Quote
Old 04-27-2015, 05:16 PM   #3
frankslagoon
Same deal with my 63 the stop was bent way up I had to bend it back down and there should be a rubber stopper on it also. It ain't easy to bend it back.
frankslagoon is offline   Reply With Quote
Old 04-27-2015, 06:18 PM   #4
HappyHooligan
Thanks Y'all, going out to check it out.
Hooligan
Old 04-27-2015, 06:42 PM   #5
uber cool
Sounds like that's the problem with mine too. Thanks for the information
my rides
59 GMC Apache fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=684337
68 VW Westy camper
uber cool is offline   Reply With Quote
Old 04-27-2015, 07:02 PM   #6
HappyHooligan
Looked under dash and nothing looked bent. Did find a hole that lined up with pedal. Insert bolt nut and a spacer. Stop installed.
Thanks.
Hooligan
