Old 04-27-2015, 04:53 PM   #1
wayno
Grille
Not sure what this bracket is made of can I use regular wire in my mig welder and weld a new nut on here? Any help would be appreciated... tonight I go and pull out my hair and see if I can't get the bottom two bolts in the front bumper.
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 04-27-2015, 05:31 PM   #2
wayno
Re: Grille
Helps if I actually attach the picture.
Old 04-27-2015, 05:36 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Grille
pretty sure the brackets are steel even on the aluminum grilles.
you could check it with a magnet.
Old 04-27-2015, 05:46 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Grille
Yes the brackets on the back of the 63 grille are steel even on the Silver Anodized Aluminum grilles.
Old 04-28-2015, 01:06 PM   #5
wayno
Re: Grille
thanks guys... welding the new nut right in there this morning - just need to extract one other one that broke off and should be able to put this thing back in place... progress is slow. Thanks again.
-Wayne
Old 04-28-2015, 01:14 PM   #6
1963c-10
1963c-10's Avatar
Re: Grille
Even slow progress is progress wayno.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-04-2015, 10:42 AM   #7
wayno
Re: Grille
Thanks Man... I have to remind myself of that. Picking up some new halogen's and and then I can focus on wiring into the new relays.
Old 05-05-2015, 08:41 AM   #8
wayno
Re: Grille
thoughts on these headlight covers..... can't decide whether I like them or not...
Old 05-05-2015, 08:57 AM   #9
1963c-10
1963c-10's Avatar
Re: Grille
Not im my opinion. Look more like they'd fit on something 40-50's
Old 05-05-2015, 09:44 AM   #10
Gooker928
Re: Grille
I agree....
Gooker928 is offline   Reply With Quote
