low vacuum= bad brakes
ok so I have a 66 c10 and it has a 383 stroker in it with a monster cam. at idle it only produces 6" of vacuum. my power brakes master that I just put on wont work. what should I do? looking for a cheep fix. and it has disk up front and drum in the back with a m22 4 speed. thanks.
Re: low vacuum= bad brakes
could try a vacuum tank
That's not enough vacuum your cheep fix is manual master cylinder. it takes around 18 in of vacuum to operate a power brake booster properly. The other option is a vacuum pump usually around $300.it's just an inherent problem with a big cam .
Between saying and doing many a pair of shoes are worn out ![]() |
a friend had a similar problem. Added a Summit vacuum pump and no worries. It's more $$ than the manual brakes, but personally I like stopping power. Especially with a bigger motor.
hydraboost set up might be an option for ya
Post Whore
![]() Join Date: Mar 2013
Ah...just put a dual cup master on there and the heck with power brakes...less vacuum leaks to fix in the future and cheaper to.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I agree.
If you already have power steering it is really quite simple to convert to a hydroboost brake system. Even if you don't have power steering, I make everything you need for both power steering and hydroboost brakes. Go fast trucks need stop fast brakes and hydroboost will definitely stop you fast.
