![]() Join Date: Jan 2009
Identifing 70 disc brake conversion
I have looked over numerous post. May have overlooked it somewhere. Is there any way to identify what front disc conversion has been done on my truck. It's a 70 Chevy that already had the swap done but I'm not sure what year I need to get drop spindles for. It has rubber bushings on the control arms. 1 1/4 thick rotors. I've done gotten myself confused by looking and reading over and over. Any help would be greatly appreciated. Thanks in advance.
2004 GMC Seirra Z71 1994 Jeep Wrangler 5.3 4L60E 241 8.8 rear 1970 C10 (under construction) |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Identifing 70 disc brake conversion
Rubber a-arm bushings means 73-87.
Just get drop spindles for the HD rotors since there was also a light duty version from 81-87. Pics would help.
Check to see if pic is there.
And again.
lolife is spot on. He helped me identify my brakes a year or so ago. I have the same setup. You'll need drop spindles for 73-87 HD rotors. Your calipers, rotors and most likely your tie rods and steering linkage are 73-87 as well. Just program yourself to buy 73-87 HD parts for your steering components and your all set.
#6 | |
It amazes me the knowledge of these board members on these trucks. No question the best forum for the 67-72's. Thanks.
Haha, I'm only passing on what Lolife taught me! Now you can do the same for the next fella in this position.
![]() Join Date: Mar 2011
Same here, I have learned so much from Keith on these front ends. He is the MAN...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
