Old 04-27-2015, 09:18 PM   #1
bbcmudtruck
Please give your opinion!
I want to hide as much stuff under the hood as possible without going crazy. Since I put the 73-87 front end under my 68 frame, I already had the prop valve on the front cross member. Ultimately I want to run the brake lines from the master to the prop valve nice and neat as well as completely out of the way. My plan is to put some braided flex lines somewhere between the cab and frame. I played around with a few different places before I finally settled on this location for the prop valve. I spent the afternoon mocking up some lines to see how it would turn out. I like it, I'm just uncertain as to whether or not I will have problems with where I put them. Do you guys see any potential problems with this? I'll clean the bends up make everything symmetrical if you guys think this will work. Thanks!!
bbcmudtruck is offline   Reply With Quote
Old 04-28-2015, 06:49 AM   #2
PGSigns
PGSigns's Avatar
Re: Please give your opinion!
Looks OK so far. I would ad line clamps to it so it has no chance of rubbing where it runs close to the nuts and bolts. You may have to do one last check with the engine and headers in it to see where they come down.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-28-2015, 08:15 AM   #3
bbcmudtruck
Thanks for the help! I bought a 10pk of cheap rubber lined aluminum clamps Amazon.com: Allstar Performance ALL18300... Amazon.com: Allstar Performance ALL18300... , but have decided against them. They are a little to light duty. Since I'm using the soft nicop line, I'd really like to use a rubber clamp of some sort, any ideas?
Old 04-28-2015, 08:18 PM   #4
PGSigns
PGSigns's Avatar
I have used those same ones on race cars for years and they work great. They will work fine on your truck.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-29-2015, 09:04 AM   #5
bbcmudtruck
Thanks for the help! I thought that the clamps were a little too flimsy, but I haven't really messed with them after first inspection.
Old 04-29-2015, 10:51 AM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Been using them for years. No issues.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-30-2015, 09:04 AM   #7
bbcmudtruck
Well thats good news, as I am having a hard time finding anything different. I suppose I'll start flaring the lines and bending them up so I can get them mounted. I appreciate the advice!
