Old 04-27-2015, 10:27 PM   #1
esbstuff
Late cab light question...
When did GM do away with the welded nuts for the cab (roof) lights. My 87 had nuts and this 89 does not... I checked the SPID and cab lights were factory installed. The roof shows no obvious signs of replacement, but I will check further... First thought was GM was trying to use up roof skins and drilled the holes themselves.
esbstuff is offline   Reply With Quote
Old 05-03-2015, 11:15 PM   #2
mrolds88
Re: Late cab light question...
My 77 doesn't have nuts for the clearance lights either. It had these stupid little j clips. I'm replacing them with rivnuts.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 05-04-2015, 06:55 AM   #3
Keith Seymore
Keith Seymore's Avatar
Does the cab have any kind of nut or were the screws just threaded into the roof skin?
I suppose it is possible they missed that this specific truck got roof lights and drilled them in repair.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-04-2015, 06:12 PM   #4
esbstuff
K
The screws were just screwed into the roof. All 5 were the same. It had the corresponding sheet metal screws vs the machine screws as the normal was... The bed had the hole for the tailgate lights too. Paint everywhere it should be, so the problem was caught before paint. The truck did not come with the gate, so I am at a loss there.
Old 05-04-2015, 08:31 PM   #5
80SPORT
80SPORT's Avatar
I checked a couple of our yard trucks....the 77 was threaded;the 81 was threaded;the 86 reg cab and 88 crew just had sheet metal screws.All are original paint.It could vary by year or even by plant.
80SPORT is offline   Reply With Quote
Old 05-04-2015, 09:53 PM   #6
v30crewcab
v30crewcab's Avatar
my 88 is just screws into the metal.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 05-05-2015, 07:02 AM   #7
Keith Seymore
Sounds like it was an intentional change for the later years (probably a cost savings).
K
1979-1986
1986 - 2019
Old 05-07-2015, 07:35 AM   #8
chengny
chengny's Avatar
Some images showing what comes in the pack containing a complete OEM marker light set (minus the harness). If you look closely at the installation/layout sheets you can see that it appeared to be a body style issue rather than the model year that determined whether speed nuts were spec'd (used machine screws)- or if the lens were simply fastened by sheet metal screws driven right into the skin of the roof:
The package included all the hardware required to do the installation either way:
chengny is offline   Reply With Quote
Old 05-07-2015, 10:10 PM   #9
80SPORT
80SPORT's Avatar
My early factory original units appear to have a special area embossed into the roof panel and the nuts(which take a 8/32 ss machine screw) welded in.
So I assume this was a spec panel for the roof marker lights.The later trucks appear to have just the hole punched and use sheet metal screws.Not sure if the factory built units with speed nuts as per the service kit.Interesting to see the engineering detail including the special sealing washers that went under the screws;I am using o rings now under the screws to seal as I was unable to source new washers.Roof marker lights were standard on R05 duallys and available on most other models -but not with Z77 Chevy Sport.They also show as available on Suburban ...but I can't remember seeing one with them.
Old 05-07-2015, 10:22 PM   #10
Anchorism
Anchorism's Avatar
So..... where did you come across such a nice complete kit?
Anchorism is offline   Reply With Quote
Old 05-08-2015, 12:11 AM   #11
esbstuff
I forgot to post that the truck in question is/was a 1989 R30 crewcab dually.
Yes its a 'R05' truck.
Old 05-08-2015, 12:15 AM   #12
esbstuff
I had a 1/2 4x4 Bonanza truck that had factory cab lights too. (Nuts in the roof skin.) But no tailgate lights.
Old 05-08-2015, 02:43 AM   #13
chengny
chengny's Avatar
Ah haha - that's funny. I don't have the actual kit I just have the pictures of it.
The pieces can be bought ala carte here:
http://www.gmpartseast.com/gmc/compo...m40k30903.html
Do get too excited though; GM Parts East actual inventory often does not reflect what they list on their site. To their credit however, they are much better most internet vendors of vintage GM parts. And they email you (usually within a day) with a list of which parts you ordered - the ones that they can actually supply.
Old 05-08-2015, 05:40 PM   #14
Anchorism
Anchorism's Avatar
whew... not cheap though thats for sure. Theyre close to $90 a light! Thats if you go with the whole shebang.
Old 05-08-2015, 06:48 PM   #15
mrolds88
And did you notice that they have 2 different #s for the lenses? Federal and Californie. guess they must be part of the emissions equipment now. LOL
93 K2500 xcab 6.5TD
Old 05-08-2015, 08:00 PM   #16
80SPORT
80SPORT's Avatar
As far as I know the tailgate lights were mandatory on all R05 dually pickups ....and not available on anything else.
Old 05-08-2015, 08:43 PM   #17
Anchorism
Anchorism's Avatar
Probably a later dated requirement and they probably have some with california requirement codes on them.
Old 05-09-2015, 03:48 PM   #18
Keith Seymore
Anything over 80" wide requires running lights. There were some one ton single wheel 4x4 combinations where the front axle width drove the tailgate and cab lights.
K
1979-1986
1986 - 2019
Old 05-09-2015, 03:51 PM   #19
Keith Seymore
At the time California regs did not allow any Amber light to be visible from the rear, so the California only lens had black paint on the rear portion; the Federal lamp was completely Amber.
Tying them to the emissions package was just an existing and convenient way to make sure they got to the right state.
K
1979-1986
1986 - 2019
Old 05-11-2015, 07:22 AM   #20
Keith Seymore
ttt
1979-1986
1986 - 2019
