Old 04-28-2015, 12:51 AM   #1
jeromio
Front disc brake dragging (and locking up)
Background: I have a 66 C10 with a McGoughy's front disc kit. Pretty sure this uses D52 calipers and corvette rotors. At any rate, the calipers are new, rotors new, hoses new, brake lines new. I am using a 97 Fbody (camaro/firebird) booster and master cylinder (and an LT1 from the same vehicle). Also a Wilwood adjustable proportioning valve. I have the 97 rear calipers with Impala SS rotors.
I did the front discs first. After a couple days of driving it, the fronts locked up completely. Weird. Ok, so I figured it had to do w/ still having drums in the back. I could drive it around and eventually the pedal would firm up and the dragging would get bad and I would have to "vent" the fluid pressure by just loosening a bleeder.
Then came the rear disc swap. No real change. As an aside, I'm not getting full braking to the rear - prop valve is wide open and rear brakes barely grab.
BUT - the major problem is this front drag. Here's a list of things I have tried:
- adjust rod all over the place. The pedal never comes close to touching the bump stop. I can max this thing out (shrink it) so that the pedal has to go to the floor to get any braking. No discernible difference in this drag problem
- Move pivot point 1 inch lower on pedal arm. Again, no difference
- Replace Master Cylinder. Rebleed everything.
- Replace MC with a more expensive one (again, rebleed)
- Check fluid level - make sure it's not too full.
- periodically jab HARD on the brakes
- Drive for a few days consciously pulling UP on the pedal with my left foot
I got nothing. I am tapped out. I do not get it. I can sometimes go a week of driving - 100 miles or so - and it all seems fine. Other days I have to vent pressure 5-6 times in a day. Or I'll feel the pedal firm up, vent, drive a few blocks and it firms back up! No rhyme nor reason.
Any ideas?
jeromio is offline   Reply With Quote
Old 04-29-2015, 06:48 AM   #2
PGSigns
PGSigns's Avatar
Re: Front disc brake dragging (and locking up)
Almost sounds like a bad hose. I fixed a motorcycle a couple of years ago that the brake fluid swelled the inside of the hose and caused the rear brake to drag.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-30-2015, 12:16 AM   #3
jeromio
Hm. That would be a possibility. But, the hoses are new and they look good. They came with the kit so I am presuming that they aren't getting kinked or otherwise malformed with use (turning, suspension travel, etc).
Old 05-01-2015, 07:06 AM   #4
PGSigns
PGSigns's Avatar
Thats the only thing I can think of unless the master cylinder you have has residual pressure valves built in and they are bad.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
