Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-28-2015, 01:20 PM   #1
Cgoldhill
Stock 350 cam suggestions
72 c10, stock original 350, 3.08 posi with a 4 speed saginaw. Dual exhaust with h pipe, stock ram horns. 8.5:1 compression, stock valve springs.
Can anybody tell me why I shouldn't run this cam?
SUM-1065
Adv. dur. 280/280
218/218 dur. At .050
.458/.458
110 LSA
Seriously, I want to know the disadvantage to this cam, besides the obvious lack of split pattern.
Cgoldhill is offline   Reply With Quote
Old 04-28-2015, 09:13 PM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Stock 350 cam suggestions
I cant looks workable to me
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 04-29-2015, 12:01 AM   #3
Captainfab
60-66 Nut
You would likely get a better response if you were to post this in the 'Engine and Drivetrain' section instead of the 'Racing and High Performance ' section. You might contact a mod and see if they will move it for you.
Old 04-29-2015, 01:01 AM   #4
tranz am
tranz am's Avatar
I would run screw in rocker studs with a cam like that. You have a manual so that makes it easier.
SUM-1065
Adv. dur. 280/280
.458/.458
110 LSA
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 04-29-2015, 12:02 PM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
With stock heads and stock exhaust a single pattern cam is not going to be the 'ideal' move. Split pattern cams help bandaid the exhaust flow crippled by incorrectly sized headers, exhaust pipes and mufflers. A stock GM SBC head will 'typically' flow in the 195-200cfm intake and 135-145 cfm exhaust (@ 0.06) just depending on what head your dealing with. The small block head target is to have exhaust flow 80-82% of the intake flow. Even though it gets 'close' at .6 lift, mid lift flow numbers are DRAMATICALLY different and the ratio get's way out of 'ideal' . Add restrictive street exhaust systems and things get worse in a hurry.
I don't know where Surgi has the summit cams ground now. Used to be a place in Mi. (gear dynamics i think was the name) but like most of the house brand stuff, I hear he started buying cams from 3rd world left handed 3¢ an hour labor. But like most things,, we don't make much here any more, and certianally not anything from the bottom end of the price range (quality costs!)
Lastly,, flat tappet cams are dated. I don't mean just by lobe design, but the oils available today simply do not support the high pressure contact and wiping effect of the cam and lifter. The internet and real world is FULL of cam failures,, even by guys running premium oils and additives. Every chance they get they remove more and more of the components that keep these motors alive. Environmental issues aside, It's part of the planned obsolesce of the early , inefficient, engines, and to promote new car sales. (not a conspiracy theorist,, this is just fact) Investiment in a roller cam package isn't waranted on a $1500 motor for sure,,, but as things progres and your forced to rebuild,, consider the cost of a retro roller vs the cost of oil changes with special oils and additives. Over the life of the motor it starts to pay for it's self,, not to mention the increased power and efficiency in fuel economy.
All that said,, Your looking for reasons to justify using this cam. Sorry,, I can't offer a single one.
lol but that's what happens when you ask a grumpy old
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
