08-31-2003, 06:51 PM | #1 |
18436572
69/70 Differences?
I am trying to figure a way to quickly tell the 67/72 trucks apart from the outside. I know it's easy to seperate every 2 years by the grill (quickest way), but between each of the 2 year series groups is what I mean.
So far, through this board and reading some catalogues, I came up with this: 67/68 Side markers on front fenders....68 has them 71/72 Rear view mirror mount...72 is glued onto glass What about 69/70? I know there are more differences on the above, such as hoods, vent window mounts, door panels, etc., but I was thinking of fast IDs. These 2 years seem to be the toughest to distinguish between. Just curious, but what the heck. |
08-31-2003, 06:56 PM | #2 |
i am curious about this also.
on another note, what about GMC's? 67 has no marker lights and sloped hood and grille w/ writing 68 has lights, and sloped hood, and regular GMC grille 69 has square hood 70 ? 71 has grille with black stripe 72 ? EDIT: dont all 71's have Disc Brake stickers on the tailgate? also, '72 doors are different...armrest is molded into door panel, there is a dimple with a philips head screw under the vent, and there is an exterior dimple
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 08-31-2003 at 06:59 PM. |
08-31-2003, 07:00 PM | #3 |
Have A Nice Day!
The difference I know of is the grill insert. Someone else will have to explain the details. I don't want to mess it up.
1970 CST K10 350/350/205
Short Bed - Fleetside Tach-Tilt-A/C-Tow Hooks Front & Rear Disc Brakes Front & Rear Posi 3.73 Gears 30 Gallon Stainless Fuel Tank SOLD 01/18 !!!!! 2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ |
08-31-2003, 07:45 PM | #4 |
70 has 7 distinct sections to the upper and lower grill inserts. The 69 is uniform all of the way along.
Other than that, i think they are pretty close. david
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
08-31-2003, 08:04 PM | #5 |
70 could come with a tilt in 69 it wasnt an option. Those are the only differences I know of other then different color options.
08-31-2003, 08:09 PM | #6 |
the grille is a subtle difference. if you look close the black parts has 7 horizontal spacers in the silver paint about an inch wide on the upper and lower part of the grille. i can get a pic of my 70 grille to show what i'm talking about if you need clarity. other than that there is no difference. 71-72 are almost identical except for the rear view mirrors and doors.
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
08-31-2003, 08:57 PM | #7 |
Active Member
Custom and CST models have slightly different door panel trim, 70's have phoney woodgrain along the top of the panel, 69's don't.
69 Custom/10 454 Turbo 400 and 70 Custom/20 350 Turbo 350, 73 cheyanne C/10 also 69 camaro Z/28 and 85 Iroc Z |
08-31-2003, 09:08 PM | #8 |
67-72 Addict!
I thought the 70 had slightly wider rear axles than 69.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
08-31-2003, 09:10 PM | #9 | |
That must be something the trucks had. My 1970 CST Blazer had the scroll pattern door panels, but never had the woodgrain on them. I am the original owner and the truck had a March 20, 1970 build date. Another 1970 difference is the front axle change from closed to open knuckles. |
09-01-2003, 02:51 AM | #10 | |
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
09-01-2003, 12:50 PM | #11 |
Truckhead
A couple of differences that I use to identify a bare cab are: 1971 was the only year that had the raised metal pad for the rear view mirror mount. There was a vent on the inside door jamb near the vin plate on 1971 and 1972. The gas pedal mount and fuse box location were different between 68 and 69. As alway's other folks should feel free to correct me if I am incorrect in this line of thought. Have fun
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
09-01-2003, 04:09 PM | #12 |
A$$ deep into trucks
Hi All!
'69-'70 differences: Cst door panels; '69 should have "bowtie", or plain scrolls. '70 should have woodgrain insert. CST headliners aren't a real good indicator, as '70's had them, and so did some mid to late '69's. If you know your color options for a given year, it's fairly easy to tell a '69 from a '70.......'70's had alot of new color options that weren't avail. in '69. Of course, the inner plastic grille is different. But somewhere mid year, the outer shell also changed. The outer shell difference is hard to notice, at first, but they did change. I've asked for clarification on this, but everyone seem to think they're the same. Still looking for an explanation!?? If you happen to be following one, just check the rear track. '69's look "bow-legged" so to speak, from the rear. They have a noticible "narrow track" rear axle. '70's have the later "wide" rear axle. I'm sure they're more differences, but I can't remember them all. To all....... Can you tell a bare '67 cab from a bare '68 cab at quick glance? OK, early '67's carried over the "fawn" interior paint from the "60-"66" gen. trucks, but mid year- on and higher trim level trucks got the body color interiors, same as the '68's. Big window/small window won't tell you much, because the big window could be had in '67 also. Give up?............Count the number of "door-stop" holes in the door jamb, on the striker plate side. '68's had one more "door-stop" rubber on each side than '67's. Mike
hardrock2 |
