04-28-2015, 02:33 PM | #1 |
'68 C10 LS1 with oil leak
I've got an oil leak at the rear of the engine behind carb. It appears to be coming out of an oil sensor? I know I've got an oil sending unit just above oil filter so I'm not sure. Also if I remember correctly it used to have a T type shape like the 3rd picture I'm attaching but now it doesn't. Did I lose something?
04-28-2015, 04:44 PM | #2 |
Re: '68 C10 LS1 with oil leak
Yes that is a oil pressure sending unit, and it will leak plugged in or not. If you have another one that your using for the guage you can just cap this port off with a plug.
04-28-2015, 08:22 PM | #3 |
the boat guy
Yup, had to replace mine. Takes a special socket
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
