Old 04-28-2015, 06:25 PM   #1
MikeB
MikeB's Avatar
73-87 steering column differences
What year auto trans steering columns will fit a 1982 truck?
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 04-29-2015, 06:17 PM   #2
left285
Re: 73-87 steering column differences
should be anything from 81 to 87. the earlier years would need to be modified slightly to work properly. ive had an 82 column in my 86 and worked fine
left285 is offline   Reply With Quote
Old 04-29-2015, 06:55 PM   #3
MikeB
MikeB's Avatar
After doing some research, looks like 79-83 pickup columns are the same for auto trans WITH and W/O tilt.
Starting in 84, I think the wipers and high beams were controlled by a stalk on the column.
Mike
Old 04-29-2015, 10:19 PM   #4
UKNOWME
UKNOWME's Avatar
Isn't the wipers on an 82 dash mounted and 86 it's column mounted?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 04-29-2015, 11:01 PM   #5
hatzie
Moderator
hatzie's Avatar
84 and later are column mounted.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-30-2015, 12:13 AM   #6
UKNOWME
UKNOWME's Avatar
Right.....
1964 Chevy c10
Old 05-03-2015, 09:10 PM   #7
cdub2010
I replaced my busted column in my '77 GMC K25 with one from a '90 suburban. Im actually swapping most of the interior over as well. I used the '77 upper column dish on to the newer column so I could keep the same ignition key and simple turn signals and still have the wipers on the dash. I used the 90 hazards, ignition and neutral switch. Everything bolted up and worked fine. I used a Borgeson steering shaft from and older project. Pretty easy except for the dang rust on the donor vehicle
cdub2010 is offline   Reply With Quote
Old 08-22-2016, 03:34 AM   #8
PowerdbyChevy79
PowerdbyChevy79's Avatar
So will a 78 column be a direct fit in a 82... Im looking at goin to a floor shift and aftermarket only goes to 78... Thx for the info
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 08-22-2016, 09:45 AM   #9
hatzie
Moderator
hatzie's Avatar
The electrical connections are the same 78-83.
85-91 will fit with or without moving the dimmer and wiper control to the turn signal stalk.
Old 08-22-2016, 10:37 AM   #10
CSHADES
CSHADES's Avatar
The 78 column has a splined output and the 82 had a DD output shaft. so you will also need a different inter shaft to make it work. Other wise it should work fine
CSHADES is offline   Reply With Quote
Old 08-22-2016, 05:51 PM   #11
hatzie
Moderator
hatzie's Avatar
You can avoid the lower shaft mismatch by using the shaft from your donor or building a U-Joint shaft.
Old 08-22-2016, 06:26 PM   #12
Matt Man
Matt Man's Avatar
I need a tilt steering column WITH cruise for my 81... seems to be a unicorn to find.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 08-22-2016, 10:27 PM   #13
MikeB
MikeB's Avatar
I was surprised to learn cruise was available in 81, and that the control was on the column. Must be very rare.
This guy is worth a try: http://www.gmtiltsteeringcolumn.com/
I bought a very nice 82 tilt/auto column from him.
Mike
Old 08-23-2016, 02:34 PM   #14
hatzie
Moderator
hatzie's Avatar
The difference between with Cruise and without is the turnsignal stalk. The columns are the same.
There are at least two cruise stalks with the early transducer controls, floor dimmer, and dash wiper switch.
  1. 1968-1980 Cruisemaster Single button in end of stalk
  2. 1979-1980 Cruisemaster with resume Single button in end of stalk and slider
Dakota digital makes two stalks for cruise with resume HND-1 & HND-3, that can be made to work with both the Cruisemaster and non wiper Cruise III columns. They are not exact replacements for either switch.
84-91 Cruise control accounts for at least two more different stalks.
  1. 2 speed Wipers Late 1984-1991
  2. Delay Wipers later 1984-1991
Stock replacement parts can be purchased for these.
While I'm on the subject...
There is absolutely no utility in getting the 2 speed switch in your 1984 on steering column. The cab harness will plug right into the delay box and the non delay 2 speed column wiper switch is around twice the price of the delay switch. To add insult to injury the non delay 2 speed column switches are hard to find too.
