Old 04-28-2015, 08:58 PM   #1
BenC/10
Lightbulb Cpp or porterbuilt???
Hey guys need some advice, i'm trying to decide if i need to get another driveshaft crossmember or not? My suspension setup is currently 3in drop in the front and 5" drop in the back, both with coils and a two piece driveshaft. i asked cpp about the differential angle changes with running said drop, and they recommended me to get their "drop trailing arm crossmember" which i dont mind upgrading to, ive also heard awesome things about the quality of the porterbuilt pieces as well, but idk if his crossmember is made for static drops? Or if he offers one for a two piece driveshaft? Any advice is helpful! Thanks
BenC/10 is offline   Reply With Quote
Old 04-28-2015, 09:53 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Cpp or porterbuilt???
You can cutoff and flip your existing trailing arm mounts to improve the pinion angle. The CPP x- member is just that. The advantage of Porterbuilt x-member is that you can tailor the pinion angle as it has multiple mounting positions. Look at pics of the two and compare them.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 04-28-2015, 10:59 PM   #3
BenC/10
Oh wow! is that something you have done? Lol.. i looked at the cpp xmember and i can see what you said about the tabs too. Also i went on the pb site, and i there were multiple versions, so i dont know which one it is lol....i did noticed that the bearing was moved from bolting on top to bolting on the bottom that would help the angle some too?
Old 05-03-2015, 04:14 AM   #4
BenC/10
Ttt, are the porterbuilt pieces made specifically for bagged trucks? Or will they work with coil sprung trucks as well? I shot an email to the fellas over at pbfab couple days ago, waiting for a response from them lol
Old 05-03-2015, 04:42 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Porterbuilt makes products for coil spring, coilover, and air bagged truck suspensions.
Quality products.
They have several trailing arm crossmembers.
For 1-piece or 2-piece drivelines.
Keith
Convert to disc brakes.
Old 05-03-2015, 02:35 PM   #6
mechanicalman
Never dealt with Porterbuilt, but if you go CPP get used to waiting and not getting any idea when your parts will be shipped, or built, or if the ore has been mined yet and sent to the smelter.
mechanicalman is offline   Reply With Quote
Old 05-03-2015, 02:39 PM   #7
BenC/10
Quality products.
Cool thanks for that, ill try and contact them again, or are there any other vendors on this board that sell pbfab pieces that can help me out?
Old 05-03-2015, 02:41 PM   #8
BenC/10
Lmao! Thats true, I at least have the "luxury" of going down to their store and try and pick my parts up, or i just buy stuff from other vendors, like summit racing haha no tax and free shipping
Old 05-03-2015, 02:44 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Exactly what I do. No problems at the counter.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-03-2015, 03:15 PM   #10
BenC/10
Awesome truck btw leddzepp! i read through your build and u said that u didnt have any pinion angle changes with your setup?? Are you still running the stock xmember or have you swapped it out? Lol
Old 05-03-2015, 03:20 PM   #11
BossHogg69
motor exploder
BossHogg69's Avatar
I used the PB trailing arm x-member on my static dropped truck with a 1 pc driveshaft - the quality is nice. But I do have a lot of CPP suspension parts on my truck too, also nice stuff, and never had any problems getting anything from them here in Arkansas. I don't know if the CPP x-member has this or not, but one thing I like about the PB one is that you can adjust it fore & aft since it has multiple bolt holes cut into it so you can get your rear wheels centered up in the wheel wells.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 05-03-2015, 03:31 PM   #12
leddzepp
Moderator
leddzepp's Avatar
Thanks! Still have the stock x-member under there. I haven't had any vibration issues so I left it alone.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-03-2015, 03:47 PM   #13
BenC/10
Cpp's doesn't and i dont like that they sell u the lil bracket to install the carrier bearing, seperatly...leddzepp i'm thinking if i should just leave it alone now too, although i could benefit from being able to route my exhaust through either one of them lol
Old 05-03-2015, 08:25 PM   #14
dirtyjim
dirtyjim's Avatar
to me the pb crossmember is a nicer product with a lot more mounting options for not much more money. i'll be replacing mine with pb
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 05-04-2015, 04:40 AM   #15
BenC/10
Yea im leaning towards it too, anybody have any pics of it installed? Perferrably with the two piece driveshaft and stuff? Haha
