![]() Join Date: Apr 2008
Upper moldings used to make frames
Had some bent & dinged up moldings that I used to make some frames for a couple of my truck advertisements. I used the undamaged areas cut at 45 degrees with some sheet metal "L" corners to hold them together.
Re: Upper moldings used to make frames
That's friggin awesome!!!
Member
That looks really cool. Any pics of the back side on how you put them together?
1970 CST LB Fleetside, 402 BB, PS, PB,AC 1968 Firebird 400 conv. 1965 Chris Craft 17' wood ski boat (SN #0001) |
Very cool and a great idea to put them to use.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
Moderator
![]() Join Date: May 2007
Very nice!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Great idea, they look amazing and will be great conversation pieces.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Used "L" brackets to hold the corners together (used a nail set to dimple the back of the moldings for a friction fit). Also used a little glue to keep them in place. Cut some 1\4 inch plywood to fit inside the back of the moldings & glued it to the corner brackets with poly adhesive. Added glass,pic, cardboard & retainers. Can't upload pics of back right now- will try later
Sweet! I want to do something similar with an old grille.
Here are some pics- hope it makes sense
Outstanding idea! I'm getting a rendition of my truck done for some motivation to keep grinding on it. This would be the perfect way to frame it up in the shop!
Still Learning
Awesome!
Cool idea, looks great.
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
#13 |
I am impressed. That's an excellent idea, and it turned out great!
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
#14 |
![]() Join Date: Oct 2004
Very cool idea!
Steven 69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners ![]() 2017 50th Anniversary Camaro SS 2004 Chevy Impala LS 2016 Chevy Malibu LT |
#15 |
![]() Join Date: Oct 2009
Very nice.
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
#16 |
![]() Join Date: Feb 2009
Very cool idea.. I sure like to know how to work with metal, weld and all that business.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#17 |
6>8 Plugless........
![]() Join Date: Sep 2007
Great work! This is an awesome idea!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#18 |
How did you cut the trim pieces ? Very nice frames you have there .
#19 |
Just used a miter saw- aluminum isn't much harder than oak
#20 |
very cool idea, looks great!
#21 |
Moderator
![]() Join Date: Jun 2008
Brilliant idea! Thanks for sharing. It looks great.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
