Old 04-29-2015, 08:33 AM   #1
RandyP
Getting Old; Going Broke
RandyP's Avatar
Lets play What Is This
88 K5, came out of the steering column area. Little help on what it is so we can get a new one. Thanks in advance.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 04-29-2015, 08:43 AM   #2
71swb4x4
71swb4x4's Avatar
Re: Lets play What Is This
Underneath the column under the dash? Looks like a brake light switch.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-29-2015, 08:54 AM   #3
RandyP
RandyP's Avatar
He had the column dropped down changing out the ignition switch and the spring came out of no where he says. Then chased down where it came from but has no idea where it goes or what it is.
Old 04-29-2015, 09:00 AM   #4
bigblock73
yeller
bigblock73's Avatar
brake light switch...inserts into the metal dash right above the brake pedal arm. Tab on the brake pedal arm engages the now broken spring loaded button.
bigblock73 is offline   Reply With Quote
Old 04-29-2015, 09:21 AM   #5
RandyP
RandyP's Avatar
Thanks guys! Half the battle is knowing what you have that's broken.
Old 05-03-2015, 11:07 PM   #6
mrolds88
With 2 sets of contacts shouldn't it also deal with the cruise control?
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 05-03-2015, 11:11 PM   #7
bdiamond
It also may control lock/unlock of the converter.
bdiamond is offline   Reply With Quote
