pictures of power steering install
Does anyone have any pictures of the steering shaft after the in tall of aftermarket power steering gear box to factory steering column. I have a CPP kit and am keeping the factory steering column so I was hoping someone had a picture on how they did it.
Posted via Mobile Device |
Re: pictures of power steering install
Check out the thread - Manual steering box for 64 C10.
Post 19 and 32 have pictures of the steering shaft install. The thread is currently on the first page. Hope this helps. |
![]() Join Date: Oct 2006
this is how I did it I cut the original shaft installed the cpp adaptor marked it and drilled it. The instructions said to use a roll pin, a grade 8 bolt or weld it, hope this helps
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
It does help some. I have the 500 series gear box so I think it doesn't line up straight with the shaft like the old one did. I will have to use a couple u-joints.
-Chapa 65 SWB step-side / 383 stroker / TH350 / 4:10 gears / static drop 4 1/2" front 5" rear. |
I used a 3/4 smooth bore to 3/4 DD universal joint to link my stock column to the shaft on the power steering box. I dismantled the existing joint on the steering shaft leaving the power steering box to get as much length as needed. The smooth portion of the universal joint needed to be welded to the column so the the steering wheel had to be centered while the steering box was centered from lock to lock then the joint was tacked. The column was removed and disassembled or final welding and great care was taken to keep the joint cool. Here are some pictures
Thank you all for the info. Hoping to the power steering done Saturday.
60-66 Nut
![]() ![]() Join Date: Mar 2007
The misalignment is a problem with the other guys' steering box adapter plates.
