Old 04-29-2015, 11:28 AM   #1
buddylee
Modified front crossmember
Has anyone modified a factory front crossmember to use tubular arms with the thru bolt rather than the ubolts??
Looking to modify xmember and eliminate weak points
buddylee is offline   Reply With Quote
Old 04-29-2015, 05:56 PM   #2
dirtyjim
dirtyjim's Avatar
Re: Modified front crossmember
there was a guy that did them years ago. he raised the lower pivot up into the crossmember so nothing hung down below it. you had to cut s lot down the bottom of the crossmember and the new lower a-arm bracket fit up into the slot and bolted to the crossomember using the original lower a-arm u-bolt holes.
I can't remember the guys name, he also do r&p conversions
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
