Hard to find!! Going Crazy
1961 Fleetside. inside the doors, under the lock and strike plate are what look like door guides. They are shaped almost triangular and bolt to door with two bolts. There is a matching guide slot in jam of door. looks to help guid door and keep from sagging, I have lost the drivers side!!!!! Checked with every parts house I can think of, no avail..........
Never Ending Projects
Re: Hard to find!! Going Crazy
Just a reminder to anyone who replies, do not make this into a Want to Buy or Sell type post as it will get axed.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Let me check tonight....I have two parts doors and I'm certain I have one I can give you to help you out.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#4 | |
Thanks |
They are called door wedges. I'm sure I have one, can let you know 1st thing in the a.m.
man, those things should be a dime a dozen I would think. I see em all the time in the wrecking yard
I have one out there. Was late when I got home and had already lost light, but I'll get it pulled tonight for you. PM me you mailing info......
1961 crewcab
the hard part is finding one that isn't all ground through due to bad door adjustment/worn out hinges... I have a bunch of bad ones!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Or one you can't get the two screws out of. I've encountered that also.
