Old 08-31-2003, 07:42 PM   #1
My Boy's Toy
Vacuum ?
The vacuum on my rebuilt 275Hp 327 fluctuates between 6 & 9 Hg. . Cant find any vacuum leaks , Any Ideas ?
My Boy's Toy is offline   Reply With Quote
Old 08-31-2003, 08:28 PM   #2
JimKshortstep4x4
Smile
If you have ruled out the carb and vacuum leaks, and the engine has new plugs, etc., I would try reseting the valves. Even though it is messy, I prefer setting them hot with the engine running. I use tabs on the rockers and a cut-off valve cover to minimize the oil splashing, loosen the nuts until the rockers click. Tighten the nut until the noise goes away and tighten an additional 1/4-1/2 turn.
If that does not help, I would check the compression and go from there.
Jim
Old 08-31-2003, 08:40 PM   #3
My Boy's Toy
Set the valves at 1/2 Turn , new plugs , pulled the plugs & there still running rich , have the carb leaned out one turn from seated.
Old 08-31-2003, 10:29 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Depending on your cam specs, that may be all the vac you can get out of it.
Old 08-31-2003, 11:05 PM   #5
My Boy's Toy
I'm running a 272 Energizer Cam , & I have a Fluctuating Hg. Reading , so i'm thinking i have a leak somewere?
Old 09-01-2003, 08:35 AM   #6
Huck
Huck's Avatar
I would bet a vacuum leak around the intake or one of the ports/hoses. Block off all hoses and use a short length of garden hose and listen as you move that hose all over the top of the engine. You may find that leak.
Huck is offline   Reply With Quote
Old 09-01-2003, 09:05 AM   #7
jay6891
Car Knocker
jay6891's Avatar
I have never tryed the garden hose route. I always use carb cleaner and spray around intake, carb, vacuum lines, and if engine speeds up you found your leak. Timing right, I maybe wrong but if it is retarded it with show low vacuum.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
