Old 04-29-2015, 04:44 PM   #1
68_Step
Ram Horns and Alt Bracket
On my 67 C10 I now have new ram horn exhaust manifolds that do not have the alternator mount built into the front edge of the left side. My old one that did have the mount broke and leaked badly at the crack.
My old bracket bolted to the water pump and the left exhaust manifold - he bottom of the alternator bolted to that. There was also a adjustment arm that went from the intake manifold to the top of the alternator.
How do I set up my alternator now? I see some folks have a bracket that bolts to the front of the left head using the 2 holes there. Is that a factory part? Or after market?
I have a short water pump and a 1975 (I think) 350 that was installed by the PO. My crank pulley is a 3 groove using the single add on pulley.
Any suggestions, alternative mounting thoughts, or part numbers would be appreciated.
68_Step is offline   Reply With Quote
Old 04-29-2015, 05:44 PM   #2
Davidf
Re: Ram Horns and Alt Bracket
Make your own bracket that bolts to the head and reaches the original manifold mounting point. Should be straight forward with some 1/4" steel plate and a little gusseting.
Davidf is offline   Reply With Quote
Old 04-29-2015, 06:01 PM   #3
michael bustamante
michael bustamante's Avatar
there was a guy on here about two weeks ago selling a set of 67 rams. i bet hed seperate
1967custom
michael bustamante is offline   Reply With Quote
Old 04-29-2015, 06:30 PM   #4
Davidf
Are rams horn manifolds with the alternator mounting boss specific to 1967? My 1971 has and uses the alternator mounting boss on the manifold. But, I also know the engine is not original to the truck.
Old 04-29-2015, 06:45 PM   #5
michael bustamante
i think theyre on the 64-66 ones with a 283 also
1967custom
Old 04-29-2015, 06:54 PM   #6
mechanicalman
I like Davidf's idea, otherwise I'm thinking you need a 72 style like I have that bolts to the head only.
I'm thinking a flat piece of 1/4" mild steel cut in a shape to catch the cylinder head bolts and extend to the alt lower bolt axis then drill through the outer bracket through the plate, install necessary spacer and you should be good to go.
But I'd for sure attempt to make a brace from the head to the rear of the alt. Or, a bracket off the front 2 exhaust manifold bolts, like maybe use some studs in the manifold and bolt a bracket to them, bend it around or weld onto it and line it up.
mechanicalman is offline   Reply With Quote
Old 04-29-2015, 06:55 PM   #7
mechanicalman
Are those 041 heads? Just curious.
Old 04-29-2015, 09:21 PM   #8
Andy4639
Old member
Andy4639's Avatar
Talking Re: Ram Horns and Alt Bracket
Is this the bracket you are talking about?
If so it's a stock item. It was on my 307 and 305. Nothing bolted to the Ram Horn.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-29-2015, 09:53 PM   #9
TBONE1964
Cluster King
TBONE1964's Avatar
For around $45.00, you can get the correct alt bracket (upper and lower with correct bolts) for the exhaust manifolds you have now. 67-68 had the boss for the bracket made on the manifold. 69-72 had the newer style bracket (like in Andy4639's photo)
Get yourself the correct part for what you have and you will not be frustrated with having the belt out of alignment and it will look like it is suppose to look.
Hope this helps,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 04-29-2015, 10:48 PM   #10
68_Step
Andy - that looks like what I need. Thanks for the pics. Is yours a short or long water pump? It is looking like time to go to Pick n Pull
Old 04-29-2015, 10:51 PM   #11
68_Step
If a trip to the local junk yard does not get me a suitable bracket I will be breaking out the grinder and cut off tool
Old 04-30-2015, 12:18 AM   #12
DLTruck1973
If a trip to your local yard does not work contact me and I can get you the correct brackets and ship them to you.
DLTruck1973 is offline   Reply With Quote
Old 04-30-2015, 01:44 AM   #13
wbc409
If you aren't worried about originality I would find the newer bracket. Shorter belt and easier pulley and belt alignment
wbc409 is offline   Reply With Quote
Old 04-30-2015, 01:45 AM   #14
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Ram Horns and Alt Bracket
Short water pump, well it use to be. I pulled the motor and sold it when I dropped the 6.0 LS in last year!
Old 04-30-2015, 09:24 AM   #15
Davidf
Aha, that makes sense. Best I can tell, the engine in my 1971 is a 283 from a mid to late 60's Malibu (230 HP). Yes, a tube spacer between a 1/4" plate and the alternator would be an easy and functional solution.
Old 04-30-2015, 10:32 AM   #16
67 cst swb
67 cst swb's Avatar
I have an extra of the bracket pictured in #8
PM me if you don't find one, I will think about a price.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 05-01-2015, 01:06 PM   #17
68_Step
Life got in the way the past couple days...
I like the fabbed bracket idea. I have sent a PM about buying the brackets, but it might be a cool exercise to play with some plate this weekend and see what I can come up with. Worst case, I goof up $5 of metal and still have the brackets.
Old 05-01-2015, 01:38 PM   #18
mechanicalman
It appears from the picture that two spacers and bolts would need to go to the fabbed bracket, one on the alternator and one to support the bracket.
Old 05-01-2015, 01:46 PM   #19
mechanicalman
Hmmm.....after studying the pics looks like there would be two bolts to attach to the plate; too easy to install the newer bracket seems plenty available (thanks to LS conversions).
I've always ran a support rod from the back of the alternator to a stud on the ex manifold to stop it from vibrating, it always did that regardless what alternator or engine I had on there. I have headers now and the bracket goes to the a/c boss on the intake instead but easier to go exhaust stud.
I used metal conduit tube, smashed and bent the ends to the right length and angles then fit it up and drilled the holes. It's enough to dampen the vibration and belt oscillations.
Old 05-15-2015, 01:57 PM   #20
68_Step
I purchased the correct bracket from a fellow board member DLTruck1973. It is the same bracket shown in post #8 by Andy4639. Fits and works perfectly (quick shipping too!). For future searchers the part number is: 3951357. Now for belts and PS pump pulley...
Thanks everybody!
Old 05-15-2015, 02:12 PM   #21
68_Step
I do not think so. I took the valve cover off to look, I thought the number was either 399882 or 398882 - reading a casting number always leaves me wondering I think I read it wrong. I compared a pic of my casting (below) to the pics at crankshaftcoalition.com and I think the casting number really is: 333882
Old 05-15-2015, 02:16 PM   #22
leftybass209
leftybass209's Avatar
Nice to see you got it figured out!
leftybass209 is offline   Reply With Quote
