04-29-2015, 11:06 PM | #1 |
Wire harness help
Hello everyone I am new to the sight and so far had been great. I am have trouble identifying a couple wires on my 72 C10 motor harness. The first one is a thick pink wire with female spade connector. The second is a black wire with a round boot.
04-29-2015, 11:08 PM | #2 |
Re: Wire harness help
Here is a photo of pink wire
04-30-2015, 12:32 AM | #3 |
I think the 1st is the blower motor.
I'm lost on the 2nd. You might try the electrical section where there are great color wiring diagram links. I actually took one to Kinkos and argued to get it printed and laminated for $11 on poster size paper. I rarely look at it, but its great. That wire looks like it may have once been orange. The color fades. |
04-30-2015, 10:36 AM | #4 |
I bet you are right on the blower motor. I have not hook power to it yet. I read somewhere else that the pink wire ran to the throttle stop on the carb when it had AC but could no verify.
05-01-2015, 07:54 AM | #5 |
I have an orange wire with a boot hooked to blower motor. Black wire boot is too big
05-01-2015, 09:26 AM | #6 |
Edit your signature to show us what your workin with like mine down below, is that a factory harness?
05-01-2015, 09:37 AM | #7 |
I'm not sure what your working on but here's the pink wire on my truck,
05-01-2015, 02:37 PM | #8 |
Is that hooked to the throttle sensor on the carb?
05-01-2015, 04:47 PM | #9 |
The pink wire runs to the idle control solenoid, which was part of the TCS system (transmission controlled spark) if I remember correctly. It does not have anything to do with A/C because my truck had it and there was no A/C on my truck, but that solenoid was there along with a relay mounted on the firewall, which was also part of the TCS. Don't know about the black wire with the boot.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
05-01-2015, 05:09 PM | #10 |
It's an idle control solinoid but it doesent do anything, prolly cause I have removed my trans controlled spark. What was left of it anyway. I honestly had no idea it was part of the tcs. Glad I spoke up on here, now maybe I'll take that junk off and just add an idle adjuster screw. Hurray for wire removal! I like it clean under the hood. I don't think I have the black wire but I know orange is right for blower motor. Maybe it's for ac which I don't have, there is a wiring diagram sticky in the electrical FAQ.
05-01-2015, 05:26 PM | #11 |
Maybe it is this, also part of the TCS. I cut the wire off mine and now it's just a cap.
05-01-2015, 05:27 PM | #12 |
05-02-2015, 07:00 PM | #13 |
Looks like it hooked to the tranny. I had mine rebuilt and they must have taken it off. That would explain why I. Can't find the hook up.
05-04-2015, 07:43 AM | #14 | |
