04-29-2015, 11:59 PM | #1 |
Currently Blazerless
Hickey / Aero 38 gallon fuel tank
This is a 38 gallon replacement fuel tank for Blazers or can be used as an auxiliary/main fuel tank in a pickup. This was the second design Hickey tank that did not use thru bolts. 200.00 no shipping
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
04-30-2015, 07:00 AM | #2 |
SWB 4x4 Collector
Re: Hickey / Aero 38 gallon fuel tank
You have my attention Rob for the crew cab. Does it look fairly clean rust wise? Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
04-30-2015, 07:38 AM | #3 |
SWB 4x4 Collector
Rob, are you heading to the Lawrence swap meet this year and if so, could you bring it? I assume though it is heavy? Trevor
04-30-2015, 11:52 AM | #4 |
Trevor, it just has your normal surface rust, should clean up with no problem. I'm not going to be able to make it too the swap meet this year...sure wish I could!! If it would help you I could beat you in Atchison Kansas with it?
04-30-2015, 09:26 PM | #5 |
SWB 4x4 Collector
Rob that would work if we can meet Saturday in Atchison. You might send me a pm with your number. Dad and I will be attending the meet and then we can meet afterwards. I can call ya a little before we leave the swap meet.
This bolts to the frame correct? Or does it wise straps? Trevor
05-01-2015, 03:53 PM | #6 |
Trevor, it uses a cradle and is suspended from the bottom of the frame rails with heavy steel brackets. I'll send you a PM with my cell number.
