Old 04-30-2015, 11:06 AM   #1
lowslow64
lowslow64's Avatar
1967 inline 6 292
Have a simple question. Have my 1967 292 engine out of truck in middle of rebuild, question is would it be better to install timing cover first before pan or pan then timing cover. Also, do they make a one piece pan gasket for this engine. Thanks
lowslow64 is offline   Reply With Quote
Old 04-30-2015, 11:13 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 1967 inline 6 292
No, they do not make a 1 piece pan seal. You need to install the timing cover first, then the pan.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-30-2015, 11:21 AM   #3
lowslow64
lowslow64's Avatar
Since I posted, I agree they do not make a one piece. Thanks for the instruction.
Marty
Old 04-30-2015, 03:11 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
Its actually quite funny...you HAVE to install the timing cover 1st because it won't work if you don't. I tried it for the heck of it and yes. lol No they don't have a single piece seal....It is a 4 piece and I Highly advise the use of a good silicon and don't be "sparring." I used blue silicon and dumped it on to the point is was oozing out the out side..then just wiped it off real good. I don't wanna be seeing leaks for a loooong time. Silicon your timing cover gasket as well.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
