Old 04-30-2015, 12:51 PM   #1
danpomeroy
Stock shocks?
Hello,
I am putting a 1" drop on the front and 3" on the rear. Just got the springs delivered and will be putting them in this weekend.
My question is do I use the stock shock lengths or does that require special shocks? I get conflicting info when I search. LMC says I don't but Brothers says yes.
Thank you for the help.
whoops... forgot to mention it's a '69 C10 2wd. I am putting an aluminum LS in. Keeping drum brakes (for now)
1969 Chevy C10
350 SBC << Going Away
LM4/4L60E << Going In
My build thread
danpomeroy is offline   Reply With Quote
Old 04-30-2015, 02:13 PM   #2
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Re: Stock shocks?
Should be in one or more of these threads, i had them saved for this same reason
http://67-72chevytrucks.com/vboard/s...d.php?t=573266
http://67-72chevytrucks.com/vboard/s...d.php?t=268817
http://67-72chevytrucks.com/vboard/s...d.php?t=335035
http://67-72chevytrucks.com/vboard/s...d.php?t=330493
http://67-72chevytrucks.com/vboard/s...d.php?t=410506
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 04-30-2015, 03:32 PM   #3
SCOTI
SCOTI's Avatar
Re: Stock shocks?
No for the fronts.
Relocated rear mounts will help keep geometry & travel like stock.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-30-2015, 04:09 PM   #4
danpomeroy
Re: Stock shocks?
Thank you for the info.
If I relocate the rears can I use stock?
1969 Chevy C10
My build thread
Old 04-30-2015, 04:43 PM   #5
SCOTI
SCOTI's Avatar
Re: Stock shocks?
Yes. That's one of the benefits of relocated stock/aftermarket brackets. You utilize off the shelf replacement shocks designed/spec'd for a C10.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-30-2015, 11:03 PM   #6
danpomeroy
Re: Stock shocks?
Thank you Guys. I just ordered my shocks.
1969 Chevy C10
My build thread
