Old 04-30-2015, 01:09 PM   #1
Diggers Dad
Air Bag Suspension vs. Coil Springs
I am building a 71 short bed w/ stock ride height. No hauling, no racing, just normal driving. Is a manual fill 4 wheel air bag suspension smoother than the stock coil spring set up? If so any board venders sell the kit?
Thanks, Mike
Diggers Dad is offline   Reply With Quote
Old 04-30-2015, 05:37 PM   #2
dubds10
Stalker Nate
Re: Air Bag Suspension vs. Coil Springs
Airbags will be smoother riding of course, however, if wanting to do it right it isn't cheap. A static drop with coils/leafs will also be cheaper and less maintenance involved. If you want to be able to lay the truck out slammed for shows, then airbags are great, otherwise it can be a waste of money to be honest. I've airbagged a few trucks and love how they turn out for shows and how they ride, but I've also seen a lot of hack jobs out there which aren't safe for road use so make sure to do it right the first time if going that route. Don't cheap out and do your homework on it. Typically requires welding on the frame if you want to go low and modifications elsewhere so make sure you have a good certified welder who knows airbag setups if you aren't one yourself.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 04-30-2015, 05:49 PM   #3
Diggers Dad
Dub Thanks for the info. I will stick w/ the stock suspension, smaller springs, taller sidewall tires. Any comments on coil springs or shocks for the softest ride?
Thanks, Mike
Old 04-30-2015, 06:49 PM   #4
michael bustamante
michael bustamante's Avatar
early classic buddy. good drop springs, shock relocators and panhard bar kits. also if you can, use drop spindles. you wont be sorry
1967custom
michael bustamante is offline   Reply With Quote
Old 04-30-2015, 08:47 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Air Bag Suspension vs. Coil Springs
If you stay with a static coil springs all the way around the truck. I would suggest the helper bags. I have them at each wheel and man what a nice ride it is!
You want be sorry.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-01-2015, 10:16 AM   #6
Diggers Dad
Andy Thanks. Were did you get the air bag helpers?
Mike
Old 05-01-2015, 11:46 AM   #7
SCOTI
SCOTI's Avatar
Thanks, Mike
The other suggestions I see are geared toward lowering or bags in coils for additional spring rate.
None of this is really required for stock height & no hauling. Stock springs work fine. The longer stock coils ride fine given their spring rate. I doubt there would be much noticed improvement swapping to bags. Bags definitely offer improved ride quality vs shorter drop springs.
If staying @ stock height, I would invest in the best quality of shock within the budget, aftermarket a-arms or tweaking the factory units for improved geometry (slight neg camber + as much caster as possible) & good quality rubber.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 05-01-2015, 12:41 PM   #8
Diggers Dad
Thanks for all the replies. Going for the late model ride from a '71 short bed!
I'll start a build thread soon.
Mike
