Old 05-01-2015, 03:30 PM   #1
skysoldier173rd
skysoldier173rd's Avatar
Wheels
I picked up a set of old school aluminum slots off EBAY. They have the large center holes and the appropriate lug spacing, no problem one would think and that is true with the back wheels, but not the front. The drums have a little pin sticking through the front in 3 spots. The flange on the back of the wheels is of course flat. The old steel wheels seem to have a recess to accommodate the pin sticking through. I'm calling it a pin but really don't know what it is or it's purpose. Wondering if I can just grind it down to allow the flange to seat flat against the drum which is what is needed. Tell me what you think and thanks. The white arrow shows one of the pins. Surely some of you have ran into this.
skysoldier173rd is offline   Reply With Quote
Old 05-01-2015, 04:23 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Wheels
My guess it it was part of the original factory rivet to hold the drums on during assembly. Someone likely cut the head off, so they could get the drums off to change the brake shoes. You can grind that down or pull the drum off and knock out the rest of the rivet.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-01-2015, 05:14 PM   #3
NVS-C10
NVS-C10's Avatar
Re: Wheels
It's a locator pin and can be removed.. some cars have that style pin and some have a bolt, but either way they can be removed. And yes the original steel wheels have provisions to clear it.
NVS-C10 is offline   Reply With Quote
Old 05-01-2015, 05:55 PM   #4
64shortbed
64shortbed's Avatar
Re: Wheels
They are rivets/pins. the hub and drum on these are riveted/pined from factory on the fronts. I ground mine off and made it where i could remove the drum without having to take hub off. won't hurt a thing.
Nice wheels by the way!!
64shortbed is offline   Reply With Quote
Old 05-01-2015, 07:47 PM   #5
NEWFISHER
NEWFISHER's Avatar
Re: Wheels
Yes grind them.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 05-01-2015, 08:17 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Wheels
Grind them, and then show us your truck with those slots. :-)
66 C20 Service Truck:
Old 05-01-2015, 10:41 PM   #7
sixTsix
Re: Wheels
SLOTS!!
Love some slots. I don't know about you bud ..but I was one happy M*fo when I picked up my set
66' Short Stepper- 350-NP440/4speed
Under Construction - http://67-72chevytrucks.com/vboard/s...d.php?t=629426
sixTsix is offline   Reply With Quote
Old 05-01-2015, 11:35 PM   #8
Lugnutz65
Lugnutz65's Avatar
Re: Wheels
Originally Posted by sixTsix View Post
SLOTS!!
Yes, you can grind the rivet heads off. I did that to mine and then took the drum off the hub so I could have the drum turned. It doesn't hurt a thing to grind them down.
Your slots look nice. Of course, I'll admit that I am partial to slots. That's what I have too. Jeep Wagoneer slots from the 1970's. So happy I found them.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 05-01-2015, 11:46 PM   #9
sixTsix
Re: Wheels
yea I remember reading here that you can ditch the rivots. I personally didn't have the issue with mine. The set I found came of a 70 c10. Don't believe mine to be wagoneers
SORRY not trying to hijack the thread I just love slots. lol
Old 05-02-2015, 12:31 AM   #10
NEWFISHER
NEWFISHER's Avatar
Re: Wheels
Slots I did up for the 65. Polished outer, anthricite center including cap with the clear flattened, chrome 3 bar.
GOD BLESS AMERICA!
Old 05-02-2015, 09:03 PM   #11
Jeff La
Re: Wheels
I hadn't found my slots yet
Jeff La is offline   Reply With Quote
Old 05-02-2015, 09:12 PM   #12
sixTsix
Re: Wheels
Jeff check your pm
Old 05-02-2015, 10:20 PM   #13
Jeff La
Re: Wheels
pm back at you
Old 05-03-2015, 02:55 PM   #14
Vincenthdfan
Re: Wheels
Mine had slots on it when I bought it
Vincenthdfan is offline   Reply With Quote
Old 05-03-2015, 05:05 PM   #15
skysoldier173rd
Re: Wheels
went ahead and ground them flat, good to go and thanks for all the comments and help.
Old 05-03-2015, 08:31 PM   #16
luvbowties
luvbowties's Avatar
Smile Re: Wheels
Might wanna remove the back portion of the rivets before trying your luck with driving w/out interference...I'd at least check & determine for sure if this is needed.
Sam
luvbowties is offline   Reply With Quote
Old 05-03-2015, 10:45 PM   #17
Lugnutz65
Lugnutz65's Avatar
Re: Wheels
Sam
The rivet can be removed by knocking it out with a punch. Not really necessary unless it is loose in the hole. It WILL be necessary to knock it out to remove the hub from the front drum. I did that when I had my drums turned.
Old 05-07-2015, 11:43 AM   #18
skysoldier173rd
Re: Wheels
Success!! The first step in moving my truck from a rat to the next step up. Just ground down the rivets and no problem.
Old 05-07-2015, 11:53 AM   #19
Lugnutz65
Lugnutz65's Avatar
Re: Wheels
Very nice!
Old 05-07-2015, 12:05 PM   #20
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Wheels
Man, do those ever make a change to your truck. Looks so much better. Totally suits the finishes.
Old 05-07-2015, 12:06 PM   #21
LostMy65
LostMy65's Avatar
Re: Wheels
Looks great!
