Old 05-01-2015, 05:59 PM   #1
jadedbird
jadedbird's Avatar
brake assembly from 98-02 camaro ls1on a 64
So I plan on running a lsx/t56. And I might be buying adonor camaro. Is there a way to run the discs on all four corners? I know for the rears cptn fab sells a bracket, but what about the front? Also I wouldn't mind running 5x4.75 bolt pattern. And I know I'll need the rear shafts will have to be redrilled
jadedbird is offline   Reply With Quote
Old 05-03-2015, 12:07 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: brake assembly from 98-02 camaro ls1on a 64
If you use the CPP 2" drop Modular spindles, these are setup to use a bolt on brake mounting bracket. This should allow you to use the front calipers but not the rotors. Should be fairly bolt on.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-03-2015, 02:48 AM   #3
jadedbird
jadedbird's Avatar
What rotor would I used then? And would I utilize the brake booster from the camaro?
Old 05-03-2015, 12:04 PM   #4
61K10
61K10's Avatar
there is something about using an le1 camaro rotor
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-04-2015, 12:03 AM   #5
Captainfab
60-66 Nut
That depends on how much fabricating you want to do. For starters, the '98-'02 F-body wheel stud pattern is 5 x 4.65" not 5 x 4.75". The front rotors are separate from the hubs, so you would have to either buy the aftermarket aluminum hubs or figure out a cheaper alternative
I don't know if the '98-'02 booster fits my booster brackets or not. I do not know the stud mounting pattern.
Yes that is correct for the front rotors. I will see if I can find that thread with the specifics.
Edit: here is the link to that thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=319487
