Old 05-01-2015, 09:26 PM   #1
cfan10
cfan10's Avatar
Cool Ac unit smoking, please help
OK, I turned the air on a few days ago, just to see if it would work and it obviously needed freon. So fast forward a few days, needed to use the defrost and I smelled something like melting plastic, saw smoke from around the ac unit in dash. I then disconnected the whole unit and in trying to do so burned my fingers pretty good. Does anyone know the cause of this?
As always many thanks for your time. It is greatly appreciated.
90 suburban 350tbi
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 05-02-2015, 12:32 PM   #2
Cabnchassis
Re: Ac unit smoking, please help
Mine had a ton of corrosion on all the connections behind the dash. I'd turn on the heater and nothing would happen, hit a bump and it would make a sparky noise and turn on. I'd guess mine was like that from either the windshield leaking (it's a gasket type not glued) or the cab lights leaking (it's a dually).
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually
1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr
1991 CR500 (95 Burb wouldn't stop catching fire )
Cabnchassis is offline   Reply With Quote
Old 05-02-2015, 04:11 PM   #3
cfan10
cfan10's Avatar
Took it apart nothing is rusty or appears to have been wet. It is scary as hell thought it would catch a fire.
Old 05-02-2015, 05:31 PM   #4
Titomars
Titomars's Avatar
It is most likely your blower switch or the terminals going to it or both. 30+ years of high current going through them builds up resistance and eventually..........poof !!
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
