05-01-2015, 10:12 PM | #1 |
Firewall pics needed-deluxe heater
Does anyone have pictures of your firewall with the deluxe heater removed? I took my heater and factory A/C out today to install a Vintage Air surefit, to my surprise I found a hole I didn't expect. I called VA to see if there was a delete cover that wasn't included in my shipment and the tech I spoke to said he had never heard of this so I sent him pictures. He was baffled and said he had to talk to the engineering group.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
05-01-2015, 10:15 PM | #2 |
Re: Firewall pics needed-deluxe heater
Here is the picture with the heater removed, I can only post 1 picture at a time on my tablet. The unexpected hole is the one between the cowl vent and th smaller square one where a heater delete plate would go.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain Last edited by 65Gregg; 05-01-2015 at 10:18 PM. Reason: Spelling |
05-01-2015, 11:05 PM | #3 |
Never seen one like that. Heres mine.
'62 Chevy K10 |
05-01-2015, 11:07 PM | #4 |
'62 Chevy K10 |
05-01-2015, 11:50 PM | #5 |
1961 crewcab
that is the hole that the dealer cuts to install the factory air conditioning unit.
all factory air cabs will have a cut hole there. here is my 65 sub with that same hole. when you talk to them again refer them to this thread, maybe they should tool up a plate for the factory air guys that choose to use their product....
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 05-01-2015 at 11:56 PM. |
05-02-2015, 12:01 AM | #6 |
That is a factory AC hole, the heater box on early factory AC units was a combo for both heat and AC. There is a flap that shuts off the heater and send air to the AC through that hole.
Projects: 65' Chevy C10 swb (rebuilt chassis) 65' Chevy Panel swb 64' Chevy C30 flatbed "above" 80' C30 "beneath") Parts: 66' GMC 2503 & 65' GMC I1500 |
05-02-2015, 09:05 AM | #7 |
Thanks everyone, I'm sure I'll just fill it and move on but I hadn't planned on this taking that long. I had hoped it was remove and replace.
05-02-2015, 10:35 AM | #8 |
