05-01-2015, 11:28 PM | #1 |
C-60???
Hi I'm new to this site , but trying to find information on a dump truck I just bought. It's a 1969 GMC 6000 I think it's a C-60 not sure though. This is my first dump truck and I've got a few problems already. I just purchased a reman. hydrovac booster the other day for it. Then I had to replace the u-joints and knuckles now I think the hydraulic pump went out. Something is knocking really bad under the truck when I engage the dump. I pulled the pto off thinking it was it but it looks ok the hyd. pump is shot I think I can't turn it all. Where can I find parts like bearings and gaskets for the pto and hydraulic pump? It's a Chelsea pto, if at worst case where can I find new parts? Thanks for all help.
Posted via Mobile Device |
05-02-2015, 12:35 AM | #2 |
Re: C-60???
Nice looking truck.
C-60 is a Chevy indication. GMC's have their own, but your truck is about equal to one. What is the GVW on it? Someone should be jumping in soon to help you with the parts you need. Bill
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
05-02-2015, 01:34 AM | #3 |
Re: C-60???
1-800-453-5703. Six States Distributors
They supply a lot of drivetrain parts and pto stuff, can even custom build you something if needed |
05-02-2015, 05:49 AM | #4 |
Re: C-60???
Ok thanks I'll try giving them a call. The GVW is 19500
05-02-2015, 08:06 AM | #5 |
Re: C-60???
It actually looks heavier. I would have guessed a little more.
Welcome to the site by the way.
05-02-2015, 06:54 PM | #6 |
So what would it be if it's not a C-60?
05-02-2015, 07:05 PM | #7 |
Re: C-60???
That matches the GVWR on my '67 C50
05-03-2015, 12:00 PM | #8 |
Re: C-60???
Hydraulic pump and PTO parts are usually a specialty vendor that deals in dump body parts .
05-03-2015, 07:45 PM | #9 |
Re: C-60???
what type of pump do you have? I just got done resealing and replacing bearings in my 1966 c60 pump and Chelsea pto. of course the dump mech. is not original for mine but if it is a Williams pump assy. I can tell you where I got my parts and gaskets ect.
05-04-2015, 07:35 PM | #10 |
My pto is a Chelsea not sure whet the pump is I gotta lift the dump bed up to see what it is. There is a lot of grime under there gotta give everything a bath just to figure out what they are!!
05-05-2015, 03:40 PM | #11 |
Re: C-60???
take some pics and post
05-07-2015, 07:54 AM | #12 |
Re: C-60???
Your VIN should have a 5 or 6 as the third digit. There are businesses that specialize in hydraulics. They are often known as bearing & transmission shops. They sell everything from pumps, to hoses, valves, fittings, bearings, seals, or any part involved in hydraulic transmission of power. Some will deal with the ptos. Otherwise, you will need to talk to an upfitter, such as a truck body works... The kind of shop that installs and/or builds bodies/equipment on cab & chassis trucks.
